Forks pallet forks
/ pallet forks #1
Sackett2
Platinum Member
Eugene, Oregon
Montana 4344HST
Found a set of woods pallet forks on Craig's list yesterday,
Paid 300, my limit, and discovered when I got there it wasn't a QD design like my tractor has- I'll buy an adapter plate from ebay soon and weld/bolt it on.
The other fault with it is the right fork is bent down at the corner, he tried to push a stump out with it.
Anyway, Repair of the fork. AFTER I get the adapter plate put on, I was thinking of reversing the bent fork and using the fel and tractors weight with the torch (or two of them) to caress it back into shape. Any concerns with the forks lifting ability after being heated? Any suggestions?
/ pallet forks #2
I wouldn't think the heating will be a problem.
You will need heat - it's alot easier to bend something down using tractor power and loader hydraulic pressure than it is to bend it up again using only tractor weight.
I guess you can't turn the fork over and then bend the fork back against another stump?
/ pallet forks #3
Hi,
Heating the fork to straighten it will leave the heated section softer than the rest of the fork. these forks have a very special heat treat which is what makes them so tuff. If you heat it up it will probably bend in the same area again. If you dont heat it there is a chance it will snap. the commercial guys would have to replace it not fix it. My point is that no matter what you do you are compromising its strength.
/ pallet forks #4
Heating probably will weaken it a bit but those forks are probably rated for 4000lbs and you are never going to be putting that sort of force on them with your FEL so I doubt it is a real safety issue.
/ pallet forks #5
I would find someone with a good hydraulic press and bend it back cold. Like others have said the forks are made of forged steel and have some heat treatment to them. They are still soft enough to bend and I have drilled a hole in the end of one of mine for a hitch pin so their not real hard just tough.
Dan
/ pallet forks
that's what I'm going to try, in a round about sort of way after I get the plate attached to it.
/ pallet forks
Ordered the skidsteer attach plate for it today, about 190.00 with shipping. Get it mounted up then work on the bent fork.
Where do you guys find the time to repaint all the attachments to match the tractor? it's all I can do to find the time to repair them...
/ pallet forks
got the q/c acdaptor plate installed and we attempted to correct the bend in the fork. We was a bit too successful, as now the fork has a up turn rather than a down :(
Used 2 acc torches and the tractor pushing down. Well 2 steps forward, one back.
/ pallet forks #9
Too often I don't. Sometimes its easier to just paint an attachment with a zinc based grey (cold galv) and leave it at that.
At least the zinc paint doesn't skin and dry between uses like enamels do.
213078 (A64276)
213078 (A64276)
40' 6 Door Shipping Container (A68183)
40' 6 Door...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
CAT D11R Ripper Teeth (8) (A68134)
CAT D11R Ripper...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
2007 AMERITRAIL  GOOSENECK TRAILER (A67714)
2007 AMERITRAIL...
