Forks PALLET FORKS
/ PALLET FORKS #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have a set of pallet forks that I use mainly for moving pallets of firewood at deer camp. I have numerous rocks that are at least partially buried in ground under food plot construction. Does anyone use tips of PF's to root out rocks or small trees?? Can't get grapple deep enough into ground to pull them out. Stone bucket doesn't dig deep enough many times since it's about 5.5 ft wide and encounters more resistance than PF's would. I don't have a BH and hate to spend the $$ for the smaller width rock grubbing attachments.
/ PALLET FORKS #2
There was a prolific TBN poster that reported success using his forks to pry out trees. He moved the forks together, plunged the forks under the root ball, then pryed the forks in a manner that made the fork tips the fulcrum of a lever. Maybe someone here remembers his name- he was from Michigan and had a running account of building his own polebarn that must of gone on for 30 pages or more.
John
/ PALLET FORKS #3
I do it all the time. Be careful as the tips of the pallet forks are way out here and apply quite a bit of leverage to the loader frame. I've actually poped the of the Quick Attach doing what you descrbe. I very rarely go after fully burried rocks until I loosen them with my backhoe or excavator. As far as roots go, the forks do a pretty good job on brush. I think you'd do better with your rock grapple. The forks won't do much against tree roots except on very small trees.
Andy
/ PALLET FORKS #4
I pry stuff up all the time rocks, concrete, break roots, dig old machinery out of tree lines, junk pile cleanup.
Keep the load centered on the loader arms & take smaller bites instead of bouncing the tractor behind stuck forks.
/ PALLET FORKS
Glad to hear you all do this successfully. Anxious to try it in the spring. Thanks
2009 Kershaw 75-G2 Sky Trim (A61166)
2009 Kershaw 75-G2...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2024 Case TV620B High Flow Forestry Compact Track Loader Skid Steer (A61567)
2024 Case TV620B...
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
