Pallet Forks ... yet another home made set.
   / Pallet Forks ... yet another home made set.
Yep ... not a lot of power at the tips at all. To pick up a log I have to get under it far enough and tilt it so it rolls back to the bucket. I'm hoping it will pick up a pallet with a dozen or so 10" cinder block on it. Probably 600 lbs.
Hanging a log from the bucket I can pick up a hardwood log 10' long, 24 in diameter .... won't do that with the forks, I tried.
I was surprised the tilt wasn't stronger, it will lift things that it can't tilt. Say you had something two feet out on the forks ... it would lift it, but not tilt the forks up.
Here is the last photo before they get beat to heck :)
   / Pallet Forks ... yet another home made set. #12
I dont know if you beat the forks to heck yet but that bucket sure has seen better days compared to rest of the tractor, what year and how many hr on it?. You have any trouble keeping forks straight? I had to double bolt mine.
It's a 95 ... was a rental, has about 1100 hours on it, about 300 of which are mine. I have a feeling the dealership swapped on a crappy bucket before they sold it to me. I TIG welded up a few cracks in the edge and it's holding up OK. Although being a rental I'm sure it saw it's share of abuse, but it also shows signs of regular dealership servicing and replacement of parts. Everything works, came with a 7.5' Woods backhoe also. Other than replacing some lines and the clutch the tractor itself has been very reliable. I did have to rebuild the backhoe, added bushings, new pins, new king pin bearings, not real expensive, just a pain. I've got a small fabrication/machine shop so I was able to do it all in house.
Yes the forks are moving around some .... I'm thinking about adding a rail on the slot where the bucket goes in that engages the front edge of the bucket that would make the fork have to pivot out to move, and the strap should prevent them from pivoting out .... picture how a T-Square slides on a drafting table with the front edge of the bucket being the edge of the drafting table. I would lose some of my maximum width though.
   / Pallet Forks ... yet another home made set. #14
I cant picture a drafting table, I can picture a table saw with the T-square push thing in a track. You thinking something like that going side to side or from from to back of bucket.
I found your tractor, it's bucket is rough to.. YouTube
Yep, that's almost exactly the same, full frame hoe looks a bit different, specially in the king pin area where mine has broken twice. Mine broke where the top cylinder pin connects to the main frame above the king pin (swivel) a year or so after I bought it, when I went to fix it I could see it had been fixed before. I fixed it properly and it's been good the last ten years.
Same idea as a table saw square, going side to side on the front edge. I "think" that the strap pulling it against the edge would keep the forks from cocking to the side .... the bar at the top of the "T" would make it want to pull away from the edge if the fork tried to cock to the side, but the strap wouldn't allow that. You could probably "slide" the fork sideways along the edge of the bucket with enough force on the fork at the bucket edge, but forces at the end of the fork would try to cock it away from the edge.
Like pushing on the long end of a table saw T-square with a rusty slot in the table :)
   / Pallet Forks ... yet another home made set. #16
I have a question of he guys that have the bolt on forks. Has anyone had the bottom of their bucket bend ? It looks like there would be a ton of pressure on it. I use a set of Cat forks on my L3700, But they are heavy, probably 350 pounds and that effects how much other weight it can lift.
The key is to have the back of the fork extend slightly beyond the back of the bucket underneath. That way the force is on the vertical part of the rear bucket. I would imagine lots of people have bent the front edge of their buckets ... the farther toward the sides of the bucket they are, the less likely they are to bend anything.
In general on my smaller tractor the hydraulics are not strong enough to bend the bucket with the forks installed.
   / Pallet Forks ... yet another home made set. #18
Son was operating my old Ford 3000. Just driving along, went to raise the forks, not really familiar with the old, under seat control, dropped the bucket instead. Forks dug into the dirt, tractor reared up on the back wheels, broke the cutting edge and totally destroyed rhe bottom of the bucket. The home made, clamp on forks were unscathed. Were made of 2x4x.188 tube. Never asked him if he filled his pants.
   / Pallet Forks ... yet another home made set. #19
A guy at work bent the bottom of his bucket and broke the cutting edge into 3 pieces when he tried to lift a large round bale with a single bolt on fork.
Not sure how badly worn it was beforehand, but he took about an 8 inch wide triangle(ish) shaped piece out of the cutting edge and bottom of the bucket.
As I recall it was able to be straightened up and then they welded a new cutting-edge to the bottom of the old one and between straightening and clamping it was close enough.
Aaron Z
   / Pallet Forks ... yet another home made set. #20
I cant get a ton of pressure on my tractor forks, somewhere around 700 lbs. A quick switch bucket is on my bucket list though, clamp on forks are the only quick fix option for a pin bucket.
M998 (A55852)
M998 (A55852)
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
2014 Ford F-350 4x4 Ext. Cab Palfinger PSC4216 2 Ton Crane Service Truck (A60460)
2014 Ford F-350...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
