Forks Pallet Forks for Loader?
/ Pallet Forks for Loader? #1
barngal
West Coast
John Deere 870, Craftsman 24HP garden tractor
Hi, I'm new here...Jenni from Sacramento, CA.
I have John Deere 870 w/440 loader, which I use around my small 5 acre horse property.
I'd like to be able to attach pallet forks, and ideally lift 2000# pallets off the trailer to put in the barn.
I'm assuming I'd need to use the loader to do this, not the 3pt hitch? And I'm guessing 2000# will be too much weight.
Can anybody comment, tell me what you purchased for this application, how it worked, etc? Thanks!
/ Pallet Forks for Loader? #2
Re: Pallet Forks for Loader;
If this is the same (click here>) 870 I dof't think you'll be able to lift a ton with it. By these specs the tractor only weighs 2515 lbs. I move ton pallets of feed and mineral with a 73 hp 2 wd and it's all I want to drive with. Hard on the front end.
Without a lot of ballast I expect the rear wheels will come off the ground if the reliaf valve on the loader doesn't dump first. And even with the ballast you may break the tractor in half. That's if the specs above are correct.
I've seen one 90-100 HP Deere break while digging stumps. It ain't pretty. And it's not just Deere, that's just the one I saw.
Thanks Charolais, this is the info I was looking for.
Yep, thats my tractor, and I've been seeing these fork attachments for the loader, as well as for the 3pt hitch.
I'd really like to be able to move around one ton pallets of feed, but I guess this tractor isn't going to help with that job. Meanwhile its unload and restack by hand (well, back and legs)...
thanks for your reply...
/ Pallet Forks for Loader? #4
If you have a couple extra empty pallets, break down the 2000# pallet, and just throw on as many feed sacks as your tractor will lift, and move those as needed. I've done that with bricks. My little tractor will not lift a full pallet, but will handle two or three partial pallets.
OkieG
/ Pallet Forks for Loader? #5
Older, used fork trucks are pretty reasonable if this is a regular, ongoing activity, you might check into one...........
/ Pallet Forks for Loader? #6
I too have an 870 but with a 420 FEL. Its capacity with loaded tires and rear ballast is 1042# at the pivot point My manual covers: 410, 420, 430 and 460 loaders, it did not provide info on the 440. Furthermore of those four loaders, only the 420 is specified for the 870. Tire type and size is also a factor. The physics on this stuff isn't always self evident, and can sneak up on you when least expected resulting in a roll-over. If perchance you do have one of the above loaders and need some info from the manual, I'd be glad to look it up and/or fax it to you.
/ Pallet Forks for Loader? #7
I have an 870 with 440 loader. The manual says loader capacity is 2065lb breakout (bucket), 1780lb breakout (lift arm), 920lb lift at full height. With proper ballast and tires could probably move the pallets, but unloading trailer might be too much. I'd talk to my JD dealer before giving up on the idea.
/ Pallet Forks for Loader? #8
My brother-in-law put shims in the loader of his Kubota to get more lift. I do not think it's a good idea, but allot of people do it. Still, a ton is too much for an 870. I second the notion of getting extra pallets. Good luck! /forums/images/graemlins/wink.gif
/ Pallet Forks for Loader? #9
</font><font color="blue" class="small">( If you have a couple extra empty pallets,
OkieG )</font>
You can never have 2 many empty pallets laying around.
You can pick up decent free used pallets if you keep an eye out for them.
/ Pallet Forks for Loader? #10
We always seem to have a truck or two coming in with merchandise on pallets. The majority of the time the drivers are anxious to get them out of their way so we save them. We have a pile of them up by our garden area. We give them away and use a few for storing our implements on (keeps them off the damp ground.)
If nothing else they make extremely short work of starting a fire to burn limbs and other debris. And if you tie a few of them together using wire they make nifty inexpensive compost bins.
/ Pallet Forks for Loader? #11
How about something like this?
http://www.forkster.com/products/forksters.asp
These are designed for skid steers, but I'll bet one of three things: 1) it could be adapted to 3pt without too much difficulty, or 2) there's someone who makes something very similar that's designed for 3pt attachment, or 3) both. It might be worth a call to the company to see if they can create a 3ph version of it.
Or if you have a quick-tach bucket on your FEL, it might already fit the front of your tractor. I'd imagine you could probably run it off the tractor hydraulic system...might run a little slower than it would with a skid-steer, but it's still easier than doing it by hand. /forums/images/graemlins/cool.gif
HTH,
Dave
/ Pallet Forks for Loader? #12
I called Lowes this morning to ask about free pallets.
They said they keep them around back.
They told me to help myself anytime.
Went and got 5 of them .
May go back and get 5 or ten more yet today.
/ Pallet Forks for Loader? #13
Check your local newspaper. Our local is always advertising free pallets. I am about ready to go get some more.
Vernon
/ Pallet Forks for Loader? #14
<font color="blue"> Our local newspaper is always advertising free pallets. </font>
</font>Vernon
<font color="red"> ````````````````` </font>
I used to get free ones from the Marietta Times (Our local Newspaper) until Woolhan Lumber opened up here and I started getting them free there. Whoolhans was closer and handier than going to the Marietta Times to get them.
I hadn't gotten any pallets in the last couple of years.
During that 2 years Whollhans went out of business and the Marietta Times moved their operations to Parkersburg West Virginia which is about 15 to 18 miles away. The Marietta Times no longer has pallets at the local office.
I called Lowes this morning and went and picked up 5 free ones.
Lows is a short 3 mile drive and pretty handy to me as it's on my end of town.
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2012 Peterbilt 337 S/A 16ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
11in. Bucket with Teeth Excavator Attachment (A64194)
11in. Bucket with...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
