Paint color match
/ Paint color match #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Ok, I have a little touch up to do. Any suggestions on a good match for thr red? Thanks!
/ Paint color match #2
If for your tractor the color is probably listed and maybe a car paint dealer would have the info or a tractor dealer. The shop I use has different tractor brands of paints on their shelves.
/ Paint color match #3
I have painted lots of things and nothing beats the quality, durability, color match and satisfaction of using OEM factory paint from a dealer. They have a vested interest in seeing their equipment look good and usually offer OEM paint at a great price to encourage it's use. Nothing looks worse, and hurts resale value, more than a bad touchup with a "close enough" color. We've all seen it.
/ Paint color match
I will try to find the OEM paint. But I have bare metal and want to cover it ASAP.
/ Paint color match #5
Dang RockyRidge, out there bashin' up your new YT347 already huh? Sounds like you're getting some good use out of her. Way to go!
/ Paint color match #6
Thin amount or Rustoleum with a brush will hold it. I do it all the time.
/ Paint color match
I picked up a can of Krylon Dual in Cherry Red Gloss. I just wanted something close for now. It is REALLY close.
/ Paint color match #8
Keep in mind, no one sells the OEM factory paint for anything.
Any paint you buy from the dealer, is a licensed aftermarket product.
While it may be easiest for most to use people to these products, I have yet to see any of them offer anything, but low end quality products, when compared to what is available in automotive finishes.
/ Paint color match
Just a follow up - I grabbed a can on Krylon Dual Paint + Primer in Cherry Red. I figured it would be just in the ballpark until I could get something better. It is REALLY close. Actually matches the metal panels better that the red on the plastic instrument cowl. And, the Krylon works on plastic, too. (I won't repaint the cowl, tho)
Krylon Dual Paint + Primer | Krylon
Caterpillar IT14G Parts Manual (A63117)
Caterpillar IT14G...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
