Paint color match
/ Paint color match #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Ok, I have a little touch up to do. Any suggestions on a good match for thr red? Thanks!
/ Paint color match #2
If for your tractor the color is probably listed and maybe a car paint dealer would have the info or a tractor dealer. The shop I use has different tractor brands of paints on their shelves.
/ Paint color match #3
I have painted lots of things and nothing beats the quality, durability, color match and satisfaction of using OEM factory paint from a dealer. They have a vested interest in seeing their equipment look good and usually offer OEM paint at a great price to encourage it's use. Nothing looks worse, and hurts resale value, more than a bad touchup with a "close enough" color. We've all seen it.
/ Paint color match
I will try to find the OEM paint. But I have bare metal and want to cover it ASAP.
/ Paint color match #5
Dang RockyRidge, out there bashin' up your new YT347 already huh? Sounds like you're getting some good use out of her. Way to go!
/ Paint color match #6
Thin amount or Rustoleum with a brush will hold it. I do it all the time.
/ Paint color match
I picked up a can of Krylon Dual in Cherry Red Gloss. I just wanted something close for now. It is REALLY close.
/ Paint color match #8
Keep in mind, no one sells the OEM factory paint for anything.
Any paint you buy from the dealer, is a licensed aftermarket product.
While it may be easiest for most to use people to these products, I have yet to see any of them offer anything, but low end quality products, when compared to what is available in automotive finishes.
/ Paint color match
Just a follow up - I grabbed a can on Krylon Dual Paint + Primer in Cherry Red. I figured it would be just in the ballpark until I could get something better. It is REALLY close. Actually matches the metal panels better that the red on the plastic instrument cowl. And, the Krylon works on plastic, too. (I won't repaint the cowl, tho)
Krylon Dual Paint + Primer | Krylon
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A61573)
2013 International...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
iDrive TDS-2010H...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
