Oxygen regulator problem
/ Oxygen regulator problem #1
MillWeld
Durham NC
Ford 641
I wheeled out my oxy-acetylene cart and opened the oxygen tank valve and the relief valve immediately opened. Did it repeatedly. Is wiser to repair/replace the relief valve or just buy a new one? It is a Victor Equip Co. unit.
/ Oxygen regulator problem #2
You should take it to a gas supplier and have it rebuilt. BTW,where did you see "regulator relief valves" for sale? I didn't know there was such thing.
/ Oxygen regulator problem #3
Just curious, but what does a relief valve downstream of the shutoff valve do (i.e. what does it provide "relief" to)?
I saw "regulator relief valve parts" on a search but never a supplier.????
The relief valve relieves excess oxygen pressure as a safety precaution. Mine is obviously defective - failed abruptly.
/ Oxygen regulator problem #5
The supply shop should beg able to get you a ball park figure to repair them. It’s usually well worth the effort.
/ Oxygen regulator problem #7
You might have a piece of trash stuck in your high pressure inlet valve. ( it's the center part inside your regulator that the diaphragm and spring pushes against.) The pressure climbs until it vents. Eventually, your diaphragm will rip. I guess you have real victor and not the economy line?
Does your nipples have the porous brass filter on the id? I crack the cylinder valve to blow dust away before mounting my regulator. The little viton seals eventually wear. It may just be time to rebuild.
/ Oxygen regulator problem #8
most of the ones I have looked at replacement is usually faster and easier, and the cost is not that much more, for many regulators,
/ Oxygen regulator problem #9
If he has a reseating pressure relief, he bought the premium stuff like SR450D. Expensive and worth rebuilding.
Mine is a Victor SR250C. I saw a Utube video of someone installing a repair kit on the exact model so I purchased the kit. Hope it is worth the effort.
/ Oxygen regulator problem #12
Doubt that the diaphragm has failed. I'd say the needle and seat is stuck. Simple to pull the bonnet off of the reg and have a look. Not much in there. Rebuild will be about $90. You can buy a descent reg for 1/2 that and it will still last 15 years or more.
/ Oxygen regulator problem #13
Good regulator. Its rubber diaphragm fails about every seven years or so. Rebuilds are about $45. Parts less labor are half that.
Make certain no oil of any form touches your oxygen reg. (Latent heat of compression + high pressure pure oxygen = a powerful, one time example of "dieseling") Always stand out of the path of your pressure adjusting screw.
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
Deere 310D Backhoe (A64047)
Deere 310D Backhoe...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
