Oxygen regulator problem
/ Oxygen regulator problem #1
MillWeld
Gold Member
Durham NC
Ford 641
I wheeled out my oxy-acetylene cart and opened the oxygen tank valve and the relief valve immediately opened. Did it repeatedly. Is wiser to repair/replace the relief valve or just buy a new one? It is a Victor Equip Co. unit.
/ Oxygen regulator problem #2
You should take it to a gas supplier and have it rebuilt. BTW,where did you see "regulator relief valves" for sale? I didn't know there was such thing.
/ Oxygen regulator problem #3
Just curious, but what does a relief valve downstream of the shutoff valve do (i.e. what does it provide "relief" to)?
I saw "regulator relief valve parts" on a search but never a supplier.????
The relief valve relieves excess oxygen pressure as a safety precaution. Mine is obviously defective - failed abruptly.
/ Oxygen regulator problem #5
The supply shop should beg able to get you a ball park figure to repair them. It’s usually well worth the effort.
/ Oxygen regulator problem #7
You might have a piece of trash stuck in your high pressure inlet valve. ( it's the center part inside your regulator that the diaphragm and spring pushes against.) The pressure climbs until it vents. Eventually, your diaphragm will rip. I guess you have real victor and not the economy line?
Does your nipples have the porous brass filter on the id? I crack the cylinder valve to blow dust away before mounting my regulator. The little viton seals eventually wear. It may just be time to rebuild.
/ Oxygen regulator problem #8
most of the ones I have looked at replacement is usually faster and easier, and the cost is not that much more, for many regulators,
/ Oxygen regulator problem #9
If he has a reseating pressure relief, he bought the premium stuff like SR450D. Expensive and worth rebuilding.
Mine is a Victor SR250C. I saw a Utube video of someone installing a repair kit on the exact model so I purchased the kit. Hope it is worth the effort.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
