Oxygen regulator problem
/ Oxygen regulator problem #12
Doubt that the diaphragm has failed. I'd say the needle and seat is stuck. Simple to pull the bonnet off of the reg and have a look. Not much in there. Rebuild will be about $90. You can buy a descent reg for 1/2 that and it will still last 15 years or more.
/ Oxygen regulator problem #13
Mine is a Victor SR250C. I saw a Utube video of someone installing a repair kit on the exact model so I purchased the kit. Hope it is worth the effort.
Good regulator. Its rubber diaphragm fails about every seven years or so. Rebuilds are about $45. Parts less labor are half that.
Make certain no oil of any form touches your oxygen reg. (Latent heat of compression + high pressure pure oxygen = a powerful, one time example of "dieseling") Always stand out of the path of your pressure adjusting screw.
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
5' MOWER (A52706)
5' MOWER (A52706)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
TAG 32in. Bucket Excavator Attachment (A60352)
TAG 32in. Bucket...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
