Owner/operator
/ Owner/operator #1
dowanisty
I have a d5g lgp dozer. What size truck and trailer will it take to haul this to the job sites
/ Owner/operator #2
I moved this post to trailers and transportation. You'll probably get more responses here.
Welcome to TBN! :)
/ Owner/operator #3
When We had our new place built , The sub-contractor had a D-4 that he carried on the back of a Peterbilt with a tilt deck for a bed . This was a 3 axle truck , ( 1 steer axle , 2 drive axles ) . Not sure the weight difference between and D4 and D5 , Or even what the weight of your D5 is sitting on the ground . That would help me search out a logical set-up for you .
Fred H.
/ Owner/operator #4
Pretty much any true medium duty 6 wheeler (I don't mean and F450) and a 20 ton tilt deck trailer will do. It is a 20K lb machine, give or take.
I used to tow similar machines with my R model Mack (300 HP, 9 Speed) and tilt deck with no issues.
If you are not comfortable or hold a Class A CDL, you may be better off hiring your moves.
/ Owner/operator #5
as others said. its 20K lbs machine
something like this
pulled behind a 10ton dump truck.... (single axle topkick)
Class A CDL required
/ Owner/operator #6
Since we believe in having others do the haul work (dirt, rock and rubble), we have an agreement with the trucking company to move our stuff around. I realized awhile ago (IMO and work) it wasn't as profitable to do everything in-house. I have to be there to load and unload the equipment, but they tote it. No CDL, equipment, tag or insurance worries on my end.
/ Owner/operator #7
Your right, it weighs 20,402 pounds, i would give and extra 1000 or 2 for fluilds and dirt in the tracks.
(2) 380/95-38 ROW CROP TIRES & 10 LUG RIMS (A63291)
(2) 380/95-38 ROW...
3PT POST HOLE DIGGER (A63291)
3PT POST HOLE...
Craftsman 33 Gallon Air Compressor (A64119)
Craftsman 33...
NEW HOLLAND TRACTOR (A64280)
NEW HOLLAND...
RAIN FLOW 1 PANEL SLEAD BEDDER BED PRESS (A63291)
RAIN FLOW 1 PANEL...
Caterpillar 966G/972G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
