Buying Advice Overwhelmed by options
/ Overwhelmed by options #21
What does the LS line offer over the standard L line? Their site isn't very clear on what you get for your $4-5k more.
LS is a tractor brand by itself,Korean and light blue.Kubota has BX,B,L,Grand L,MX,M ect.
/ Overwhelmed by options #22
Everybody has opinions, so I will toss mine into the mix. Keep in mind I am not experienced with larger machines, and only use a tractor for gravel road maintenance, moving heavy junk around, post hole auguring, and snow clearing, which is the one critical thing for us, situated up a hill with about 750' of lane to clear, sometimes 2-3' of snow, and no place to push it. I upgraded from a gear drive B8200, which worked fine, but I got tired of twisting around to see what the rear blade was doing, and my wife wouldn't operate a gear drive tractor, to a '96 Kubota L3130 HST. No rear remotes, but a 6' QA bucket in front (and a 84" plow for snow) telescoping 3 point arms, the usual Grand L features, all in all a very clean tractor, 1000 hours, no issues once I went thru it and cleaned it up, and $12500. My only concern is the weight- well over 5000 lbs with loaded rears, so I can't drive it over the yard unless the ground is real dry, or frozen. For snow, that weight will be great. For post holes, not so great. Sure, it could use more HP, but it has enough to do what I need, and is a big framed machine, very solidly built. I would expect it to last many years, with no more than regular service. The LA723 loader is more than I will ever need. I wouldn't rule out used machines, unless you plan on entering tractor concours de elegance... it will get dirty and bumped with use. I would love a cab in the winter, but wouldn't want one the rest of the year, plus it wouldn't fit in our little barn with a cab. Folded ROPS is fine.
/ Overwhelmed by options #23
Thanks, will be looking through some of those.
Unfortunately I am in Ontario, Canada so that is a bit far away.
So I guess the general consensus is that I'm "aiming too low" with a 30-40? My concern is that I don't want "too much" tractor.
I still haven't made a final decision on the new/used front, just a used one would have to be pretty new I think.
Unless you have a very specific size limitation (like a barn stall width, or garage/shed/barn overhead door height limit), it's hard to have too much tractor when you're talking about Compact, or even Utility machines. Something like the Kioti DK or NX series, LS R or XR series would handle most needs you're likely to encounter, have good warranties, and reasonable prices (under $25K is easily possible fully decked out).
/ Overwhelmed by options #25
I can guarantee the hours are not correct in the ad, maybe 175 hours on the new meter.
Look at the wear on the bucket and tires, and grime around the engine compartment, and 2wd.
If it was 175 hours, you would see some paint fade, but otherwise the bucket and tread depth on tires would still be like new.
Just looking at the pic a would guess several thousand hours.
/ Overwhelmed by options #26
Things can be shipped.
/ Overwhelmed by options #27
The biggest advantage of a late-model used tractor today, is it would be free of the "tier-4" diesel requirement. "Tier-4", which is required on all new diesels, robs hp, while costing more money. Unless you are a rich environmentalist, that does not make much sense for the small acreage, infrequent user. Unfortunately for you, this has driven up the cost of these "newer" used tractors, especially if they are 4wd with loaders. Personally, I would skip a step, and consider an older, gas tractor such as a Ford 2000 or 3000. For about $4000 today in Canada, these can be converted to Natural Gas fuel which would then also satisfy all of your "environmental" concerns 10 fold over a "tier-4" diesel. A diesel can not be converted to run on straight NG. I can't see it being too long until most all tractors sold will be powered by NG. I would just run that old Ford on the "petrol" gas for a few more years, until the NG conversion cost comes down a little. For the mechanically un-inclined, those old Fords are quite easy service and find parts for, and are extremely durable compared to today's tractors.
Your only drawback would be the lack of 4wd, which would hurt you most if you are looking at lots of front-loader operation, and/or disking. Not that big of deal for mowing and plowing however. A rear blower or blade on a 2wd tractor with loaded rears/chains works real good for clearing snow. Forget about a front blade however. Although a gas tractor is considerably less efficient than a diesel, on that small of size, it is hardly enough to make up for the greater cost/liter of the diesel.
/ Overwhelmed by options #28
Robs hp? That's incorrect.
1985 Ford 2910 Tractor | farming equipment | Belleville | Kijiji
Is this the kind of tractor to which you are referring?
/ Overwhelmed by options #30
People seem to think this, but reality has proven otherwise. Compare a Kubota MX5100 and the new Tier IV compliant MX5200. Both have 148.6 cubic inch engines with turbocharging. The MX5100 makes 52.2 gross HP, and the MX5200 makes 54.7 gross HP. More power, higher fuel efficiency, and less emissions.
As far as costing more, I'm not seeing a major difference in price (I'm shopping for a new cabbed 50hp tractor now). When I got numbers on a Kioti DK50SE and compared them to an NX5010 it was about $1000 more for the NX (configured identically), but the NX has new features such as auto-throttle, auto PTO, etc that the DK didn't have, so it's about a wash other than that the NX has slightly more power, and better fuel economy.
This is another theory that doesn't seem to hold true. I've bought a new tractor, and started shopping for another new tractor in the last 18 months, and the prices on used machines that I also considered haven't changed significantly. Quality, late model, 4wd compact tractors with FELs on them have held their value very well for more than just the last year or two.
If someone isn't mechanically inclined, or at least experienced, suggesting a 15-30 year old machine is just going to leave them stranded at some point. Many of the folks suggesting an old machine seem to own several, so if one goes down, they can use the other machine(s) until they get it fixed. That doesn't sound like the case here.
/ Overwhelmed by options #31
Kubota Tractor Acceptance Corporation (KTAC) had a post on here recently, justifying insurance price increases for new and 1-2-3-4-5 year old tractors on the basis of higher resale/replacement costs for used Tier III tractors, which have depreciated less because of higher costs for Tier IV tractors.
My Kubota L3560 (Tier IV) increased $5,000+ in price over previous model L3540 (Tier III) but it is not an apples-to-apples comparison. The L3560 has been improved/upgraded/redesigned in many ways, including two horsepower increase, relative to L3540.
I just spoke to a Kioti dealer. He has an open station DK40. If we do the 0% financing we can't do the free front end loader but it would be about $32k (give or take) with the loader installed.
/ Overwhelmed by options #33
Wow, that's a ridiculous price! A high price here would be something like $25k.
/ Overwhelmed by options #36
I have read that the 0 percent financing costs you more in the long run when you figure in the promotions that it excludes.
You'd have to figure it out.
Yeah, I'll do the math but I'm getting the impression that one way or another he was going crazy high and that sets the tone doesn't it? From what I've read having a good dealer is just as important as a good tractor sometimes...
/ Overwhelmed by options #38
In Canadian that price is way, way too high.
For reference, I paid $33900 US dollars for the base Cab on NX6010 and that price included the loader and 72" bucket. .
However, don't be put off by high prices when you first start. I had people quoting me 65K for Masseys, 55K for Deeres, $54k for the Kubotas I looked at too.
My point is that you should shop another dealer.
/ Overwhelmed by options #39
You can play with the payment calculator here Free Loader Program | Kioti Tractors
Say you paid 23000 US + your 13% canadian tax of 2990.00 = 25990 at the Kioti prefered rate of 5.5% with the free loader, 0 down for 72 months would be 424.62 per month, x 72 months= 30572.64 with finance charges, that's about 1500.00 cheaper than the 0 percent price you were quoted that nixed the free loader promotion.
From what I have read, they get their money either way, and the 0 percent costs you more.
You might want to send a PM to member kiotiken, and see who he bought from, he is in Ontario and has bought a couple Kiotis ,and from what I gather from reading between the lines, was pleased with the pricing he got.
Good Luck
/ Overwhelmed by options #40
The main reason I am suggesting a newer gas tractor with good parts availability, is for the long term. I expect the bottom to fall out of the diesel engine market within the next several years. Because the Otto cycle works even better on NG than PG, a gas engine is easily converted. The supply of NG is almost unlimited in Canada and the US. That is not so with oil, which the diesel requires. If this guy wants to get his money back out of his tractor 20 or more years down the road, I definitely think gas is the way to go. The way diesel prices have gone over the last 10 years, what do you think they will be then? Compare the trend in NG. It is going to be very difficult to sell a diesel if it costs that much more to run. That fuel served us well, but it has almost run its course in my opinion. Yes he may get better dependability today out of a new diesel. He could also buy a half a dozen old gas tractors for the same money and keep his whole family working if he wanted to. If Deere and Kubota engineers are not working on NG designs right now then I am afraid they will be in for a rude awakening fairly soon. Maybe they are to busy working on the various diesel "Tier" upgrades to look that far into the future.
Ez-Go Express L6 (A64912)
Ez-Go Express L6...
2016 CHEVROLET COLORADO PICKUP TRUCK (A66091)
2016 CHEVROLET...
20' Container (A64912)
2015 Mercedes-Benz C300 AWD Sedan. (A66738)
2015 Mercedes-Benz...
2014 Dodge Grand Caravan Van (A66738)
2014 Dodge Grand...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
