Overheating 3540
/ Overheating 3540 #1
the_wolfman
After about one hour the temp gauge hit 100 on it way into the red ...
I have replaced the thermostat and the problem still remains ...
Outside temp between 80 and 100 ...
This has happen anytime I run it up to one hour continuous ...
Open to any suggestions as to what I should check ...
The dealer said they do not check timing or valves as I remember that could lead to over heating?
They did put a 50/50 mixture in radiator ...
Only 14 hours on engine ...
thanks,
greg
PS: This is a 4 cyl. Jinma
/ Overheating 3540 #2
100 C or 100 F ? and is your radiator free of dirt on the cooling fins and geting good air flow, if it's restricted that would cause it also
just some things to consider
Jim
/ Overheating 3540 #3
Scroll down near the bottom of this chinese tractor page and you will find this subject "Jinma 224 Temp". Here is a link http://www.tractorbynet.com/forums/chinese-tractors/103049-jinma-224-temp.html
Just about everything I said in post #8 applies to your situation also. Poor waterflow, Poor airflow, leaking headgasket, timing or simply overloaded...
What are you trying to do during this hour when it overheats?
/ Overheating 3540
MrJimi: 100 c ... all clear in the radiator area ...
Ronmar: You bet I read that thread ... No bubbles ...
I may have found the answer ... You all tell me ...
I raised the loader very high, basically above my head and it did run cooler ... at least it did not approach the 100 c mark ...
When I was thinking restriction I was not thinking loader until I RE-read the thread Ronmar pointed out ...
/ Overheating 3540 #5
The loader is out away from the grill at least 2 feet, I wouldn't think it would have much effect unless you are at highway speed or happen to be pointed into a breeze.
/ Overheating 3540 #6
What kind of dealer doesn't/can't check valve and injector timing?? I would kick them to the curb.
Yes, overheating can be caused by incorrect injector timing but not valve timing. Check for airflow restrictions through the radiator, blow it out back-to-front with compressed air if possible. Other things to check are the air filter element and V-belt tension. Has the cooling system ever been flushed? Are you overloading the engine? What color of smoke comes from the exhaust?
/ Overheating 3540 #7
Maybe check / verify the actual temperature with another gage / thermometer ? Could it be the gage or sender unit is not reading right?
Larry
/ Overheating 3540
Thank you Rob & GuglioLS ...
I will check the temp with a thermometer in the radiator cap opening next time it heats up ...
I would buy a mech. gauge but not sure with the threads mate ...
Rob, I am going to flush the radiator asap and black smoke ... I do not think the dealer flushed it only filled it ...
thanks very much!!!
/ Overheating 3540 #9
Bad idea. That could land you in the emergency room.
If the dealer didn't flush it, chances are good there wasn't any anti-freeze in there either. Don't stop at flushing the radiator, flush the engine block too. Twice.
Black smoke is unburned fuel, which lends support to the injection timing suggestion.
//greg//
/ Overheating 3540
//greg//
Hey greg ...
Oh I know that opening the cap is a little messy ... will have gloves on and a towel over the cap ...
The dealer said they put a 50/50 mix antifreeze in ...
/ Overheating 3540
UPDATE:
added a cheap catch can and it did get fluid ...
1st time it hit 100 opened the cap and no problem with no spillage and temp read under 200 F ...
2nd time it hit 100 opened the cap and it blew big time with spillage - by the time I was able to get then thermometer temp read around 200 F but with so much antifreeze now missing it was hard to get a good reading ... Had to re-fill with water for now ...
Question 1: At what temp would antifreeze push out of the radiator and into the catch can?
At least that might tell me what the temp is getting too ...
Question 2: Besides overheating, what else would cause antifreeze out of the radiator and into the catch can?
Checked for bubbles at 80c and 2200 rpm and none there ...
Thanks,
Greg
/ Overheating 3540 #12
Go buy a inexpensive non contact infared thermometer. You shouldn't have to take the radiator cap off, as Greg said, this is a good way to get burnt bad.
The catch can should be configured as a expansion resovoir like in an automobile. The hose from radiator cap fitting should go below the fluid level in the catch can. As the sysem heats, the pressure builds untill the limit on the radiator cap is exceeded. The cap then opens and vents any air in the top of the radiator and fluid to the catch can to maintain a system pressure. Heat transfer is more efficient under pressure as boiling point is retarded. That is why opening a system under pressure is so dangerous, you instantly drop the boling point well below the current water temp and it boils instantly, errupts violently and releases a large ammount of the cooling system contents.
As the system cools, there is a small check valve in the radiator cap. As the system cools, the fluid contracts and goes under vacume. This vacume draws fluid back in from the catch can and keeps the radiator topped off with fluid.
A stream of bubbles comming from the hose in the catch can could be an indication of a head gasket leak. This also puts oil and combustion residue into the coolant so an oily ring will also start to form in the catch can as this material makes it's way to the can.
I will say it again: Your problem is one of or a combination of the following:
1. Poor waterflow
2. Poor airflow
3. timing
4. overloaded/overworked
5. or perhaps a leaking headgasket which isn't really overheating. It adds pressure to the system so the cap vents more often and vents mostly combustion gas(looks kinda like a boilover). This hot gas rises to and surrounds the temp gauge sensor causing the gauge to rise, when the actual fluid temp is not that great.
I don't recall ever reading an answer to the question below...
What are you doing with the tractor during this hour when it overheats?
/ Overheating 3540
1. Poor waterflow
2. Poor airflow
3. timing
Any of the following:
1. Using only the FEL to scoop and pour a raised mound of dirt (very little strain on the motor)
2. Using the 5' box ripper (about 2 to 3 inches down in very soft dirt)
3. Using a 6' blade to move the dirt from the box ripper ...
I now am thinking there was problem from the start - upon delivery - when the tractor was unloaded and it was used to remove the attachments it overheated then and blew water from the radiator ... It has been down hill ever since ...
/ Overheating 3540 #14
I would pressure test the cooling system with an eye toward detecting a blown head gasket if you can get ahold of a pressure tester. Also warm the tractor with the cap off and watch for flow in the radaiator, could be a defective water pump,although it is my experience that the head gasket is more likely. If the tractor had kept its cool at one time, I would almost guarantee blockage of airflow through the radiator by seed, dust etc that makes it past or around the screen. This is by far the most common source of overheating on these tractors. You cant see this type of blockage and you need to use a strong water flow (some use compressed air) but in either case you dont want to use high pressure for fear of bending the fins which will inhibit flow the same as if it was still dirty.
/ Overheating 3540 #15
I wouldn't think it should overheat doing any of that.
You might also try running without the thermostat installed. With the thermostat removed, you should be able to see flow in the top of the radiator wih the cap removed as soon as you start up without waiting for it to get to a temp high enough to open the thermostat. If you don't see good waterflow, you at least know where to look... With the thermostat out, you could also drop the thermostat in a pan of hot water on the stove and watch it open at the appropriate temp. With the thermostat removed, you should also see a change in the heating symptoms. It should take a long time to warm up. No change in symptoms would indicate a blockage somewhere else in the system.
/ Overheating 3540 #16
Welcome to the life of high quality Chinese tractors. It seems if you get a good one of these your life is good. If not then it can be a PIA. Ours has been hit or miss with 190 hrs currently. We too have had overheating issues and when it's hot outside (90 or so) it will slowly move up the temp scale. (over the period of several hours of medium/heavy use) The best thing to do is to keep the rad fluid changed and clean with water wetter and a 60/40 mix. I have the Ron/mar overflow tank update also and that helps. Also, check the valve timing and injector timing. The rad fins plugs easily I've found when brush hogging dry hay type fields. The finish deck doesn't generate as much hay due to those fields being mostly green. I flush my radiator fins about once a month or so now usually just with a air gun. Seems to work well. Ours does not blow much black smoke except when under a very heavy load such as going up a steep hill with the brush hog going with 4 - 5 foot weeds. One question i'd have for you is does the temp come down when you stop the implements, park it in the shade and idle the engine at 1000rpm for 5 mins ? The temp should lower. If it doesn't the first thing I look at is the rad. 1000rpm is the recommended speed for idling and cooling down before shutting down the unit. I've found this to be accurate info and works very well on ours.
Steve
/ Overheating 3540 #17
Further to RonMar's thermostat recommendation, it's only a test procedure. If removing the thermostat actually improves cooling, do NOT continue to work the tractor with no thermostat. Doing so will typically cause the engine to operate at too LOW a temperature. It should be replaced with a new thermostat of the proper size and temperature range (80C). If removing the thermostat does NOT improve the cooling issue, you've done nothing more than simply eliminate it as a possible cause for the overheating.
I know you said there's only 14 hours on the tractor. But I'm still a pound or two short of confidence that your cooling system is clean, inside and out. It only takes a few hours work in dry/dusty conditions for airflow restriction to start building. You have to be able to see light through 100% of the radiator fins before you can claim you've got 100% airflow. Often the only way to do that is to physically remove the radiator from the tractor. If the coolant is brown looking, a heavy duty cooling system cleaner should be used on both the radiator AND the engine block. I had to use TWO cans on my Jinmas before clear flush water started coming out the block drain.
Short version; almost all the suggestions offered to you so far assume that an overheating problem exists on a known CLEAN cooling system. Only then should you be breaking out the test equipment and tools.
Oh, and one other thing I haven't seen mentioned is the fan shroud. Assuming you actually have one, the cooling fan blades should be INSIDE the shroud. Since tractors move too slow to push air through the radiator fins, you must rely on the fan to PULL air through. On one of my two Jinmas the radiator and shroud were poorly installed, to the point that there was a large gap between the back of the shroud and the front of the fan blades. I had to move the radiator back on it's frame mount AND center the shrould on its radiator brackets. After the fan blades were actually CENTERED INSIDE the shroud, the engine operating temp came down several degrees and stayed there.
//greg//
/ Overheating 3540
Alright ... I am heading off to the store to get flush, (proper)l antifreeze, oil etc ...
It is just under 20 hours nows (20 was the recommenced service time) ...
Going to do a complete service ...
When I am done I will first run it with out the thermostat with water to see what happens ...
If it stays cool I will add the thermostat ...
If it stays cool I will drain and add the antifreeze ...
I will be double sure nothing blocking or in the fins of the radiator and double check the air filter ...
Fan and shroud are all a ok ...
When I replaced the thermostat it went in the same way I took it out ... I have replaced them on cars before so I think I got it in right side up :)
I will let you all know how it works out ...
What can I say but THANK YOU ALL!!!
/ Overheating 3540 #19
One of contributors had done a nice write up on a Modification. I think his name was Gugulio (Sp) or something lke that. He had trouble getting the engine up to temp was his problem. I think his engine was a 395 3 cyl. He replaced the theromstat with a Napa brand one with a little modification. He paid particular attention as to sealing of the bypass circuit. If the bypass circuit is left open the engine will overheat. The OEM thermostats are suspect in quality. You'd have to do search or maybe one of the other writers hear remember this modification and can expand on this. bjr
/ Overheating 3540 #20
I found the link to the thermostat mod I was talking about .
