Overheating 3540
   / Overheating 3540 #1
the_wolfman
After about one hour the temp gauge hit 100 on it way into the red ...
I have replaced the thermostat and the problem still remains ...
Outside temp between 80 and 100 ...
This has happen anytime I run it up to one hour continuous ...
Open to any suggestions as to what I should check ...
The dealer said they do not check timing or valves as I remember that could lead to over heating?
They did put a 50/50 mixture in radiator ...
Only 14 hours on engine ...
thanks,
greg
PS: This is a 4 cyl. Jinma
   / Overheating 3540 #2
100 C or 100 F ? and is your radiator free of dirt on the cooling fins and geting good air flow, if it's restricted that would cause it also
just some things to consider
Jim
   / Overheating 3540 #3
Scroll down near the bottom of this chinese tractor page and you will find this subject "Jinma 224 Temp". Here is a link http://www.tractorbynet.com/forums/chinese-tractors/103049-jinma-224-temp.html
Just about everything I said in post #8 applies to your situation also. Poor waterflow, Poor airflow, leaking headgasket, timing or simply overloaded...
What are you trying to do during this hour when it overheats?
   / Overheating 3540
MrJimi: 100 c ... all clear in the radiator area ...
Ronmar: You bet I read that thread ... No bubbles ...
I may have found the answer ... You all tell me ...
I raised the loader very high, basically above my head and it did run cooler ... at least it did not approach the 100 c mark ...
When I was thinking restriction I was not thinking loader until I RE-read the thread Ronmar pointed out ...
   / Overheating 3540 #5
The loader is out away from the grill at least 2 feet, I wouldn't think it would have much effect unless you are at highway speed or happen to be pointed into a breeze.
   / Overheating 3540 #6
What kind of dealer doesn't/can't check valve and injector timing?? I would kick them to the curb.
Yes, overheating can be caused by incorrect injector timing but not valve timing. Check for airflow restrictions through the radiator, blow it out back-to-front with compressed air if possible. Other things to check are the air filter element and V-belt tension. Has the cooling system ever been flushed? Are you overloading the engine? What color of smoke comes from the exhaust?
   / Overheating 3540 #7
Maybe check / verify the actual temperature with another gage / thermometer ? Could it be the gage or sender unit is not reading right?
Larry
   / Overheating 3540
Thank you Rob & GuglioLS ...
I will check the temp with a thermometer in the radiator cap opening next time it heats up ...
I would buy a mech. gauge but not sure with the threads mate ...
Rob, I am going to flush the radiator asap and black smoke ... I do not think the dealer flushed it only filled it ...
thanks very much!!!
   / Overheating 3540 #9
Bad idea. That could land you in the emergency room.
If the dealer didn't flush it, chances are good there wasn't any anti-freeze in there either. Don't stop at flushing the radiator, flush the engine block too. Twice.
Black smoke is unburned fuel, which lends support to the injection timing suggestion.
//greg//
   / Overheating 3540
//greg//
Hey greg ...
Oh I know that opening the cap is a little messy ... will have gloves on and a towel over the cap ...
The dealer said they put a 50/50 mix antifreeze in ...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2015 Isuzu NPR-HD Flatbed Truck (A51691)
2015 Isuzu NPR-HD...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A51692)
2015 Ram 5500...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
