over -run clutch problem
/ over -run clutch problem #1
vincewine
waynesboro,georgia
yanmar 2000
I have got a clutch that I could ONLY get 1 grease zerk removed at this time. If i can't get the other out. Will it work just as well?
/ over -run clutch problem #2
One time, when trying to remove an overrunning clutch, I was able to get both zerks off but couldn't locate the pin because of all the hardened grease and debris inside. I simply compressed the C-clip holding the clutch together and slipped the outer housing off, exposing the inner components. After a little cleaning with a wire brush, the pin was obvious, and I could drive it out. Put a bucket under the clutch to collect the little parts as they drop out. Reassembly is no problem.
Frank Z.
/ over -run clutch problem #3
I've pumped grease into one of the zerks on an overrunning clutch with the second zerk removed and the grease came out the opening so my guess is you only need to put grease in one.
/ over -run clutch problem #4
Those grease zerts serve 2 purposes. 1) to get grease to the moving parts inside the clutch and 2) provide an opening so that the retaining roll pin can be inserted and removed. Either one will provide grease for the entire assembly.
Mike
/ over -run clutch problem #8
That is why it has only one grease nipple. The ones with 2 have the retaining roll pin. One grease fitting is all that is necessary, but they put two because they had to have 2 holes and they either had to put a plug in it and a grease nipple is cheaper!! (My guess)
Mike
/ over -run clutch problem #9
i have one of the non-quick disconnect type. I had to remove 1 nipple to install the roll pin Then put it back on. i have never had it off again. i agree that it is only there to cover the hole.
Bushhogged on friday and it works just fine with 1 . but it will be a problem if i have too take it off.
UNUSED WOLVERINE RSB72-72" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2021 ASV RT-40 Compact Track Loader Mini Skid Steer (A61572)
2021 ASV RT-40...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
44in Hydraulic Grapple Bucket Mini Skid Steer Attachment (A61572)
44in Hydraulic...
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
