Outrigger hitting hydro line?
/ Outrigger hitting hydro line? #1
Agentiron
Northwest Indiana
I just picked up a ck20 with the TLB package. I noticed that my outrigger will come up and really give a good wack at the top. I found it this morning really putting alot of pressure on that line. The platform is acutally deformed and caved in from where the line is being pressed on by the outrigger.
Is there a fix for this on the 65 series hoe?
Thanks
Jay
/ Outrigger hitting hydro line? #2
We have not had that problem with the KB2365 only the KB2375
They do have a bump stop kit you can get I will have to get you the part # tomarrow.
/ Outrigger hitting hydro line? #3
Is this (see photo) the area where the outrigger is hitting the hydraulic line? On mine the lines are zip tied to the side (if you look hard you can see the black ties) so it does not seem to be hit by the outrigger. Are your lines tied in such a way that they are being pinched?
/ Outrigger hitting hydro line? #4
I call it a minor design flaw, but thats part of the learning process. I've learned feather the outriggers when retracting them. I put these on to help but since discovered that I can't put the transport locks on with them on. That was a year ago and I haven't transported it anywhere yet, so I guess its not a problem right now. I also added a couple of tywraps to keep the hoses from being pinched as well.
Steve
Wallace, I appreciate that info as you get it.
Island ans Steve
That is the location of the problem. As I sit on the hoe, the side to my left seems to have barely enough clearnce. The side to my right is hitting at the fitting. I can zip tie the line, but the fitting is mounting to the outrigger and is rigid. There is no way I can see to get it out of the way. I can see any spacer will make the latching mechanism for transport unuseable.
Thanks guys
Oh by the way Island you should see the stump I removed today, and it was not located in the garage! /forums/images/graemlins/grin.gif
/ Outrigger hitting hydro line? #6
Go to your local NAPA and order part number
BK 770-5150 and that work perfect.
Thanks Tractorhill
Could you give me anymore info about the part, or what else I may need to mount it?
Thanks
/ Outrigger hitting hydro line? #8
Even with the bump stops in my humble opinion it is wise to feather the outrigger when raising. It is still a good jolt to the hoe if you just yank back on the stick. Sounds like you just got the machine. Practice a little and you will find it is not the big a deal. However, if there is a solid connection hitting somewhere it will not take long to break that off. In fact, I would think about one good wack otta take care of it.
PRACTICE! PRACTICE! PRACTICE! /forums/images/graemlins/grin.gif
/ Outrigger hitting hydro line? #9
While mine doesn't actually hit the fitting, it can give a good whack. As has been suggested, feather that stick when you're raising the stabilizers and don't let it bang.
You might also find that you CAN put a small stop at a location that will just barely keep it from hitting, and still be able to lock them in.
John
/ Outrigger hitting hydro line? #10
</font><font color="blue" class="small">( Go to your local NAPA and order part number
BK 770-5150 and that work perfect. )</font>
/forums/images/graemlins/confused.gif fill us in here please.
I can't hold on much longer /forums/images/graemlins/crazy.gif
/ Outrigger hitting hydro line? #12
We have only had this problem on one 2375 hoe, where the outrigger hit the frame of the hoe hard enough to damage the fitting on the cylinder causing a leak. Kioti has bumper kits available. The dealer just needs to ask for them from their service rep. The kit is made up of rubber bumpers and the bolts, washers and nuts to attach them. You have to relocate the name plate and the kit even includes the pop rivits for that purpose. I don't see a kit part number on the bag, but your rep will know what to send you, just ask. /forums/images/graemlins/laugh.gif
Thank you gentlemen for your advice. My dealer is aware of an occasional issue with the larger hoe, and is sending me out the bump stops for my unit. Thanks for your help as usual.
Jay
/ Outrigger hitting hydro line? #14
</font><font color="blue" class="small">( Kioti has bumper kits available. The dealer just needs to ask for them from their service rep. The kit is made up of rubber bumpers and the bolts, washers and nuts to attach them. )</font>
I can't understand why these rubber bumpers are not included with the backhoe from the beginning.
In my opinion they should be.
On my Rhino backhoe the rubber bumpers were included with the hoe.
/ Outrigger hitting hydro line? #15
Thanks alot Vince. Now I have to put on my shoes and jacket, run (well walk maybe) out in the cold, uncover my Rhino and see if it has the stops /forums/images/graemlins/smile.gif
Hey Rick,
If your on here, does mine have the stops? /forums/images/graemlins/confused.gif
Tom
/ Outrigger hitting hydro line? #16
</font><font color="blue" class="small">( Now I have to put on my shoes and jacket, run (well walk maybe) out in the cold, uncover my Rhino and see if it has the stops /forums/images/graemlins/smile.gif)</font>
I will be suprised if it doesn't.
/ Outrigger hitting hydro line? #17
I have the 2375 on my ck25 and I believe it came with the bumpers. Did they start putting them on at the factory or only if someone had the problem?
/ Outrigger hitting hydro line? #18
Rhino does not have that problem.
/ Outrigger hitting hydro line? #19
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Kioti has bumper kits available. The dealer just needs to ask for them from their service rep. The kit is made up of rubber bumpers and the bolts, washers and nuts to attach them. )</font>
On my Rhino backhoe the rubber bumpers were included with the hoe. )</font>
All the new ones do.
/ Outrigger hitting hydro line? #20
</font><font color="blue" class="small">( All the new ones do. )</font>
Glad to hear it.
I just got to wonder what in the world they were thinking to not have been installing the rubber bumpers all along..
My 2 cents worth..
iDrive TDS-2010H...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
