Outlets wired backwards
/ Outlets wired backwards #21
What size breaker do you have on the #10 if its 30 you can not use that outlet if it's 20 you must have a 20 amp receptacle not a 15.
Wapedia - Wiki: NEMA connector
BTW never hooked a GFI backwards will it work or will it trip?
/ Outlets wired backwards #22
??? Then the light would never go out, but that couldn't happen,
You got hot to light and the return is hot to the switch. The switch interrupts the return. :D
/ Outlets wired backwards #24
I think it was a good point, Mike... If the plugs are wired in reverse polarity AND the ground is removed all it would take to ZAP the bajeebers out of you is if you touched the case of a cheap appliance and a metal window frame on an aluminum sided house. Weird stuff like that happens.
Now that you've explained the connection to reversing the polarity and grounding, I agree. It was clear as mud before. :D However, I think Egon has nailed the direct issue to the OPs question, i.e., flipping a switch will not interrupt the hot wire if the polarity is reversed which could get worse, if there's a bad ground. All in all, correcting it is the right thing to do.:)
/ Outlets wired backwards #25
Hopefully the house is wired properly, and the mistake was made by the person who did the finish work.
Another cause for concern is if every part has price tag on it.
In the 80's switches, and receptacles with push in terminals were common. If you have those, put the wires under the screws. Do not use the push in connections.
I would find someone who is qualified to have a look at the job, to be sure if it was all done properly. It usually takes about 10 seconds looking at the inside of the service panel, to tell if the person who wired it knew what they were doing. Things like an overloaded neutral wire, improper connections, and undersized wire, can be a serious issues.
/ Outlets wired backwards #26
Hey guys,
This can be a serious problem and I want to say that you should not assume your wiring is correct just because a licensed electrician did the job. I had an old house rewired two years ago by a licensed electrician, because I didn't have the time to do it myself. After he finished, and was paid I might add, I went behind him and found that all the receptacles in the house had the ground wire disconnected. His hired help was not licensed and did a poor job. Not a grounded outlet in the house, and my grandchildren were moving in. I can assure you he got a piece of my mind, and he personally came back and did the job over.
/ Outlets wired backwards #27
I used to own a house where some "handy" previous owners did their own home remodeling and removed plugs while doing it. The whole house was 2-wire construction built in 1950. When power came to the circuit breaker box, the earth ground was attached to the same bus as the neutral. The handy owners decided to replace the receptacles with three-prong plugs and just connected the third prong to neutral. Unfortunately, they also reversed the hot and neutral wires on one wall, making the chassis ground to anything connected at the full hot potential. There were no ground fault connectors in this whole house.
I guess this condition must have continued for many years and then I discovered personal computers. This room just happened to be my office. I bought a new computer and printer to sit on my desk. I hooked the computer and monitor into one wall receptacle, but didn't have a power strip, so I hooked the printer into the other wall receptacle and started to run the printer cable to the computer. POW! As soon as the printer cable's shielded jacket touched the computer's plug, there was a big flash and the CB popped in the box. To this day, I don't know how I avoided being electocuted. I remember how my heart raced when the sparks flew and how I was certain my new and expensive computer was toast.:mad:
I pulled the cover on the wall receptacles and immediately saw the problem. I fixed the miswire in both receptacles and checked every other one in the room. Luckily I was smart enough to not reset the breakers until I checked out what was wrong. I was even more lucky in that both the computer and the printer worked perfectly when I again powered them up. WHEW! :D
/ Outlets wired backwards #28
I ran multi-strand awg 10 in schedule 40 conduit in my barn to a new addition that was at the opposite end from where the load center is located. Why did I use 10 gauge? It was free. I had 2, 300 metre spools given to me, one white, one black. That's about $600 on copper wire I didn't have to spend.
I added 6-15 amp and one 20 amp circuit which were minimum 80 feet runs to the first junction. I simply pig-tailed all connections to switches, receptacles, fixtures with awg 12. It's no problem to fit the 10 gauge wire into a 15 amp breaker. Just had to buy colored electrical tape
Took a long time to wrap green or red electrical tape around 150 metres of wire.:eek::eek: (sorry, just kidding!):rolleyes:
/ Outlets wired backwards #29
Yeah. That's the right thing to do. I'd better do it, too. :p We've been in our house for 13 years and there are still some electrical problems left over from the last owner. Nothing major, but it should be corrected.
/ Outlets wired backwards #30
What are the consequences, dangers, problems that result from using outlets with neutral and hot reversed? Jack
Jack
Back to your original question, what are the dangers? I was a refrigeration, air conditioning, appliance technician for 38 years and found many dangers with such an arrangement.
Many times when a motor or heater burns up, it shorts out to ground. In many older homes that originally had 2 hole 110v outlets without a ground, the outlet went bad over the years and were replaced with a 3 hole outlet without a ground wire connected.
When the motor shorts to ground on a grounded outlet it will blow the fuse but if the outlet is not grounded it sends 110 volts to the chassis of the unit. Many times I opened the door of a refrigerator before the customer answered my question, "What problem are you having with the refrigerator?" I always knew the answer before they said "it shocks when you touch it". :eek:
One of the main dangers in having a switch wired backwards is that the hot wire will not turn off when you turn the switch off. It just turns off the neutral. When I change a light fixture I never turn off the circuit breakers, I just turn off the switch. Doing this while standing on an aluminum ladder with reversed wiring can result in severe injury or death.
I do not envy your difficult job that lies ahead but you must correct the situation ASAP. I recommend that you also install GFIs in the first outlet in each circuit for further protection as you remove and repair them.
/ Outlets wired backwards #31
How appropriate that Elkhart is the RV capitol of the world! :p
Yep, in fact the reason I was there was because I had found that my RV was a little overloaded, so I went out to talk to the customer service guy at the manufacturer, and he sent me to a particular fellow at Dexter Axle, and I got a complete custom built suspension from the frame down; i.e., springs, shackles, wheels, tires, brakes, axles, etc. I bought all the stuff (cheaper than I expected) and the RV manufacturer paid one of their dealers to install all of it.
thanks Tally - - I've been thinking about GFI's. But I totally don't know which outlet is 1st in each circuit. I'm not finding much organization in which circuits control what. I've been identifying the circuits as I go along - - sometimes it is strange what a particular circuit controls.
Jack
/ Outlets wired backwards #33
When I worked as a appliance tech, I had a dishwasher that the heating element came on while the cust was on vacation. The polarity was reversed, and the door even if it was open broke the common side of the line, not the hot side, so when the heating element shorted, the element came on and stayed on all the customer was gone. There was no fire, but everything inside was melted. Try reaching under a built in dishwasher, thinking the door is open, I'll be safe!
Drills, sanders, and many hand tools rely on proper grounding. Some of the parts inside could present a hazard if something went wrong, even if they are all plastic.
Most solid state devices require a proper ground, microwaves, furnaces, gas ranges with spark ignition.
You could if necessary wire nut a short piece of #12 wire to the #10. It would work ok, but the more connections you have the more likely you are to have problems.
/ Outlets wired backwards #34
How are the circuits wired at the panel, i.e., did they reverse the white and black there too?
It's hard to believe a licensed electrician reversed the white and black and used 10 gauge wire.
We are working on a apartment building right now that the old wiring was all reversed. The white wire was set to the hot side in the panel box and all through the house. Don't know why it was done that way but the guy who did it is the electical inspectors brother and his shop is right across the street. It really doesn't matter to us though as when working with electric you always verify the hot side before tying in to existing work.
/ Outlets wired backwards #35
I didn't understand the ground prong comment either since it's irrelevant to your question. :confused::rolleyes:
The tester confirmed it's wired correctly at the panel. As others mentioned, the only issue would be one of polarity. Since you have not had any problems, maybe it's not an issue. Perhaps an electrician could comment....about polarity.
I thought the original poster wanted some comments about potential (a little joke there) consequences. It's OK to be confused and not understand, but the outlets being wired incorrectly is a safety issue. As for polarity, well, AC has none.
Use some common sense, people. If it were not an issue, why did they even bother?
One more thing. If you examine your lamp cords, etc, you will notice that the insulation very often is molded such that the "hot" (also called "line") conductor has a distinguishing feature (molded lines, may be different color, etc) to identify which conductor is which. They don't do this without an excuse.
/ Outlets wired backwards #36
Not sure about the older ones, but these new "smart" gfi's will not even let you energize if not wired correctly, and wont reset until fault is removed if they do trip.
Egon, still not exactly sure what you mean :) but it doesn't sound good.
I had an electrician wire a direct short in a ceiling light fixture, he got mixed up with the white wire acting a a switched leg and just twisted it up with the other whites/neutrals in the box, when I flicked the switch, POPPPED the breaker. He was doing alot of E work in the house at the time but was gone for the day, so I corrected the short problem, when I told what he did he denied it!
Jack
Jack,
If you want to know what other outlets are fed thru a particular one, as you are doing those outlets one at a time, when the outlet is disconnected and wires are safely separated and not shorted to the box, go and turn the breaker back on and check to see which if any other outlets are unpowered.
It's a slow process but one which you are going thru anyhow, that way you could protect the other outlets with one GFI, they also have gfi breakers to control the whole branch circuit.
Typically you only need gfi's in bathroom, kitchen, basement, garage or anywhere outside. Well I guess that's most of the house except bedrooms and living room, halls etc.
What is an AFCI?
http://www.youtube.com/watch?v=hFU5J6JOKkc
Here's the new thing, Arc Fault Circuit Interrupter "AFCI" for bedrooms etc. Not sure if it's code yet but they have been out for a few years now.
JB.
/ Outlets wired backwards #38
Tdog my question has not been addressed what is the size of the breakers?
I think a 15 or 20 amp outlet on a 30 amp breaker is more of a problem than reversed polarity.
/ Outlets wired backwards #39
This is a very frustrating thread to read through. There is a fair amount of misinformation being tossed around, and wrong terminology along with it, that there is no good place to start to try to offer some help.
Hopefully the OP will carry through with straightening out his mess of a wiring job and not have anyone "shorted" out or a fire break out. That means being sure the right breakers/fuses protect the circuits too.
Along with the bad information, there is also some good information. I guess it is up to the readers to carefully sort it out, and not put some of these things into practice.
/ Outlets wired backwards #40
Excellent point re: the wire that is switched. This is true everywhere there's a switch or a switched appliance, light, etc.:eek:
That's the main reason you switch hot. On a light socket the hot is normally tied to the center contact (button of the bulb base). This is a lot harder for someone to touch than the threaded ring. Hence it is safer.
HONDA generator (A64553)
HONDA generator...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
3142 (A63117)
3142 (A63117)
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2007 Mitsubishi Fuso FE84D 10ft. Box Truck (A66736)
2007 Mitsubishi...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
