out rigger cylinder
/ out rigger cylinder #1
terramite t9
looking for 2015 t9 outrigger cylinder for my 2015 t9. where can i get a aftermarket one for good price. i know i can get them for 400.00 but that is a crazy price!! any help would be great!!!! thank you
/ out rigger cylinder #2
Site sponsor Surpluscenter.com or Bailey hydraulics. The original is likely rebuildable by most hydraulic shops too
thank u agjones! looked at them on the web sites u gave me. im just afraid i will order the wrong one. someone put a chief brand on it but the hose port on one end is in the wrong place so i cant put the cylinder gard on it. can any one tell me what brand and the number of a cylinder that is plug n play for a 2015 T9 outrigger??
/ out rigger cylinder #4
Look into the tie rod type cylinders if the 400 is too steep. It's not all that much for a drop in fit up...
The tie rod type can be loosened and rotatated to get the port alignment you need.
Can be found at tsc or northern. Or contact Bailey about what you need.
Is your cylinder beyond repair?
when i bought it the two clilinders were mismatched. i found cylinders from magister 2 inch bore x 14 inch stroke with 1 inch pin holes with 22 inch retracted x 36 inch extended. i hope they work - i ordered two yesterday for 250.00
i think it said they have sae 6 ports whatever that means?? im still learning about hydraulic fittings -- jic -sae-oring boss etc. was at rural king the other day looking at fittings for hydraulics. there are so many i guess i will learn about hydraulic fittings.
thank you otlski. terramite guys need to stick together!!
/ out rigger cylinder #9
Agreed! I should also add that I do business with those guys regularly. Them being in PA and me in CT, I get my parts faster than I could take time off from work to buy over the counter. I might order Saturday (usually when I discover my troubles) and have my parts at noon on Monday.
x (A68191)
x (A68191)
INDUSTRIAL GOLD 133 GALLON COMPRESSOR (A67714)
INDUSTRIAL GOLD...
CONVEYOR BELT (A67714)
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
3144 (A63117)
3144 (A63117)
PALLET OF 1 5/8 HYDRAULIC HOSES (A67714)
PALLET OF 1 5/8...
