OP
2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,271
Thank you for the additional perspective.A 2-wheel tractor with a flail mower will absolutely annihilate that briar patch. It's the correct tool for the job, no need to keep deliberating about it. If you don't want to buy one, I agree that renting or hiring someone for a day make a lot of sense, especially if you just want a once-and-done approach. Buying a 2-wheel tractor on the other hand is an investment - yes it's expensive, but it's a versatile machine that will last you many years. If your only goal is to clear this patch, buying brand new probably doesn't make sense. Used packages do come up often enough and Earth Tools has a bulletin board and lots of good deals.
I have all the implements that are being discussed here: flail mower, double action cutter bar, brush hog, small lawn mower, big lawn mower, flamethrower. The flail mower is exactly what you need for this job and would be the only tool I'd reach for in the case. You already have a nice clearing up to the patch so you can offset the handle bars so that you are working in the cleared space, and cut right across it. It'll mulch it so nicely that you can wear flip flops while you cut.
I think a misconception is that because they only have two wheels, they are thought of as "big lawnmowers" and put in that pricing/utility category. They are not - they are tractors in every sense of the word, and the implements they drive and just as rugged as anything you can get for larger 4-wheel tractors.
Other random thoughts based on things you've brought up:
* When clearing land, things happen fast. Speed is not your friend. Even 0.8 mph will be too fast some times and you'll be wishing for a half gear slower (or a hydro)
* You shouldn't consider anything other than the largest foam filled tires you can get.
* I've never spun the wheels unless I drive it right into a big tree or solid object. You'll bog the engine down first if you've got too much material under the deck.
* You won't need to be working hard behind the levers, because you won't need to apply pressure to lift the deck. You want it flat on the ground.
* I'd only be taking "nibbles" if I thought there was an obstacle somewhere that I couldn't see, like a partially buried concrete footing or a rusting pile of iron that someone piled up.
* Doing a 180* turn while mowing in 3rd gear will have you running to keep up, but in all other conditions it's a walk in the park
The BCS 779 is the only hydro I see for sale new at a current list of $7,504. IMO, it would be much better for tailoring ground speed to both ground and vegetation conditions, but is quite a bit more than the used Grillo 110 under consideration at roughly $3,500.
The hydro would eat some of the available power, but I agree that slower is better in this situation, particularly when the vegetation is so tall and there is so much more volume of material for the frail to shred.
Mowing with the Bachtold, it was absolutely better to nibble and cut up the vegetation while it was standing instead of cutting it and then trying to grind it up laying on the ground. If the vegetation entangled the Bachtold, it became much more labor intensive to get it free, especially because there is no power reverse on the Bachtold.
In my experience, it is very important to be able to grind up the vegetation as I go. I'm just not sure how all that material will feed into a flail mower even if I used a hydro to slow it down. Maybe that offsets the additional cost of the hydro, but I'd want to be pretty sure it would work before paying double for the tractor.
Bigger diameter wheels on a gear drive would increase the .8mph speed by what, something like 10%? On the one hand, larger tires would help but at the cost of increasing ground speed which would hurt, IMO. Not sure about this aspect.
Have you any additional thoughts on buying a Bittante flail versus a Berta?
I am familiar with the land before it grew up in brush. There isn't any hidden junk unless some spy balloon has crashed and I didn't notice.
Being able to swing the handlebars seems like a decided plus for getting away from the yet to be cut standing briars. The other decided plus would be having a power reverse.
