ORC questions
/ ORC questions
kenmac said:
I have had no problems with my quick disconnect. I prefer the quick discommect. Goes on easy comes off easy
What reason do you have for disconnecting it?
Robert
/ ORC questions #13
Robert
auger. Here's the 1 I installed
/ ORC questions
Ya, I guess there is not much need for one with an auger.
Robert
/ ORC questions #15
Once I install an ORC, I never take it off. I don't have any equipment that interferes with it. [disc harrow, renovator, boxblade etc.] It certainly dosen't "hurt" anything to leave it on as long it isn't in the way of anything.
The roll pin is a tight fit, it's made that way for a reason. It has to be perfectly lined up to go in though. I back up the underside with a sledge hammer or somthing hard to start the pin, once it starts it goes in easier.
/ ORC questions #16
Sledge hammer back-up sounds like good advice. using brass hammer/hardwood buffer to drive pin NO? when I drive roll pin (slow/soft beating)100 easy taps/VS/5 hard taps. otherwise it expands and I never get it in there/ drift out/ throw pin away start over new pin? How about digging in the bolt bin, find tite fit bolt? spin w/drill&emory bolt on unthreaded shank part of bolt if neccesary? remove easy? allways try to keep drive line as straight as possible especially when in strain works for me? my 2cents.
LMTC Quote:You could email us and buy a quick-attach OR coupler. Any pounding against the side of your tractor's pto (which is what you are doing when trying to pound a roll pin through a coupler and the shaft) is a very bad thing. How true!
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A60736)
2014 MAGNUM...
1011 (A61165)
1011 (A61165)
2018 Dodge 5500 Bucket Truck 4WD (A61307)
2018 Dodge 5500...
Rhino DB150 (A57148)
CFG Industry ECAG QA Auger w/ Bits (A60463)
CFG Industry ECAG...
MAGNUM PRODUCTS LIGHT TOWER (A60736)
MAGNUM PRODUCTS...
