Optimizing towing vehicle
/ Optimizing towing vehicle #61
1/2 ton with 12K tow rating, I don't think so. The hitch may be rated at 12K with WD but the truck is somewhere around 9,000# max with 4.10 gears. 3.73's are 8,000# according to my 2004 GM guide.
This is for LB trucks. Add 200# for SB trucks.
Chris
Actually since you are such a huge fan, I am surprised. Ford's advertising their 2015 aluminum F150 with a max tow rating of 12,200. That is due to a loss of almost 700lbs truck weight. Not sure of configuration, just quoting their ad. The ad did mention with the eco boost engine.
/ Optimizing towing vehicle #62
Here's the quote off the Ford web site,
Tow more than any other light-duty pickup. And tow smarter than ever.
• New 8-inch Productivity Screen* – provides a screen dedicated to towing information
• Class-exclusive** Dynamic Hitch Assist* – line-of-sight guide helps direct your hitch ball to the trailer receiver
• Smart Trailer Tow Connector* – alerts to burned out or unlit trailer marker lamps, brake light and trailer battery problems
• Standard Trailer Sway Control – helps keep your trailer on a stable course
•Trailer Brake Controller (TBC)* – factory-installed and integrated into the instrument panel; helps synchronize the truck and trailer brakes
Best-in-class 12,200-lb. maximum tow rating**
... Less
*Available feature.
**Class is Full-Size Pickups under 8,500 lbs. GVWR.
/ Optimizing towing vehicle #63
Yes, a newer 1/2 ton. They have all been above 11K since 2011.
His is a 2004. That's 3 to 4 generations back. Worlds of difference.
Chris
/ Optimizing towing vehicle #64
Yea I know, just had to rattle your cage though! :). Was looking at the FMC web site and with peak torque at 2500, it's impressive, but like I said my Duramax isn't leaving my stable.
I see Ford isn't immune to working the numbers though. Instead of talking about increased HP numbers it hp to weight ratio. The increase there helps more at higher speeds than low, but it's marketing. I wonder if those new numbers are according to the SAE J2807 standard?
Good to see SOMEONE finally develop a standard for truck ratings, they need so standardize the RV (trailers and 5th wheels) weight and length standards. Also based on reading the utter confusion, even experienced commercial drivers have with a trucks capabilities, those standards need to be clarified AND simplified. Every truck should clearly state in laymans terms (vast majority of rv towers) what is legal.
/ Optimizing towing vehicle #65
Yes, the 2015 F150 meets the J2807 standard for tow ratings. Supposedly, the F250-F450 will be rated that way at the next revision of the standard.
Aaron Z
/ Optimizing towing vehicle #66
Pretty amazing half ton, I gotta say. If I ever get to where I can afford a new truck (doubtful since I am retired) the Fords will be high on my list since the 6.7TD seems to be a reliable engine. I have always preferred the interior of Fords over GM, but the years of diesels I could afford were those of the 6.0.
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
2022 EZ-GO ELITE...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
