Optimal Sway?
/ Optimal Sway? #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
I have just purchased a 55-gallon sprayer that I will be using on my B2320.
When its full, I am going to have 450 pounds or so of water sloshing around in the sprayer. How much horizontal sway in the lower links should I allow for in order to avoid any potential damage to the 3PH components?
Steve
/ Optimal Sway? #2
I'll be interested to see what others say. I try to keep sway to a minimum. The thought process is that added sway gives the implement a "run for it" to gain momentum till it hits the limit.
/ Optimal Sway? #3
I have to agree with chim. Less sway with that particular use is optimal.
/ Optimal Sway? #4
I crank my sway bars tight, on everything. Just what I do, not sure if it's Kosher or not. One or two inches of play seems plenty.
/ Optimal Sway? #5
Another vote for as little sway as possible.
2016 Lincoln MKC SUV (A61569)
2016 Lincoln MKC...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
