Optimal Sway?
/ Optimal Sway? #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
I have just purchased a 55-gallon sprayer that I will be using on my B2320.
When its full, I am going to have 450 pounds or so of water sloshing around in the sprayer. How much horizontal sway in the lower links should I allow for in order to avoid any potential damage to the 3PH components?
Steve
/ Optimal Sway? #2
I'll be interested to see what others say. I try to keep sway to a minimum. The thought process is that added sway gives the implement a "run for it" to gain momentum till it hits the limit.
/ Optimal Sway? #3
I have to agree with chim. Less sway with that particular use is optimal.
/ Optimal Sway? #4
I crank my sway bars tight, on everything. Just what I do, not sure if it's Kosher or not. One or two inches of play seems plenty.
/ Optimal Sway? #5
Another vote for as little sway as possible.
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
43055 (A55851)
43055 (A55851)
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2019 GMC Sierra (A60352)
2019 GMC Sierra...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
