optima batteries--quick questtion
/ optima batteries--quick questtion #1
flemdog
INDIANA
JD 4310
I have a 4310 and just took it to the dealer because the battery leaked. They replaced the battery and oil cooler and I want to use the optima battery (red top) I think from reading tbn.articles from a year or so. Could someone maybe remember the model number that fits the 4310 and any other advice that would be helpful. thanks very much.
/ optima batteries--quick questtion #2
I use the Red top group 34/78s for my trucks and will do this with my 3720 provided it fits. I'm not sure what group size is needed.
For tractor/top post only, the Group 34/34R unit wil work.
http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive/starter/technical_specs.html
Interstate has them also:
http://www.ibsa.com/www_2001/content/products/product_autosealed.asp
SC34U has both terminals (you can keep the side posts covered and SC34 A and R are top only.
I always go for more CCA and reserve capacity if it fits.
/ optima batteries--quick questtion #3
Most of us use the Yellow top D51R. Fits perfectly, I haven't had one problem since I switched,
Mine was about $100 from Remy Battery.
/ optima batteries--quick questtion #4
Yep the 51R yellow top fits. I don't think any red top will work. Note that you'll have to fabricate your own battery hold down as the factory one won't "grab" the bottom of the Optima batteries. I used a generic hold down kit and it worked.
Also you can find the Optimas 51R stocked at Sears or Autozone if they're in your area.
/ optima batteries--quick questtion #5
Crabgrass,
Where did you get the generic hold-down kit?
Steve Z
crabgrass and rrf: So you guys are saying go with yellow top battery instead of the red top because it is a better battery. Does it have more amps than the red top, more durable? Thanks
/ optima batteries--quick questtion #8
Optima doesn't make a red top in a 51R package. Only yellow. A little disappointing simply because the yellow has a shorter warranty and costs about $20 more, but hey it works, and I don't have to worry about the battery eating through my hydaulic cooler lines anymore.
/ optima batteries--quick questtion #9
You're right, the space is pretty narrow. Also blocks the direct air flow to the oil cooler...
/ optima batteries--quick questtion #10
The yellow top is designed to take deeper discharges. It should stand up to heavy loads better. But the biggest feature is it fits and works.
Yellow looks better in a Deere, anyway...
/ optima batteries--quick questtion #11
I put in a size 31 in a JD5200, I think it was a bluetop. Marine start/deepcycle.
2006 MACK CV713 (A67714)
2006 MACK CV713...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2014 KOMATSU D65PX-17 CRAWLER DOZER (A65056)
2014 KOMATSU...
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
Menzi Muck M520 Walking Excavator Mobile Excavator (A66734)
Menzi Muck M520...
