Opinions - Replace B21 TLB with this B26 TLB?
   / Opinions - Replace B21 TLB with this B26 TLB? #41
Finally got the new cylinder - took 16 days via usps to get here. Its an oem cylinder so fit very well
View attachment 2151544View attachment 2151544
Also it’s winter and a good time to get the leaking piston on the backhoe stabilizer repaired - Kubota wanted $100 for seal kit - e-parts had them for 40 so got two.
My $50 Plow with $1,500 worth of weld metal and $1,000 in mods and maintenance!
Nice new older plow - I used mine this week - worked great - Hyd angle works well. Not sure what you mean by $1500 in metal and 1K in mods tho? Was that for the third function or?
   / Opinions - Replace B21 TLB with this B26 TLB? #43
@Mike, what brand of cab do you have on the L39? Or is that diy? I have the B26, and at times having a cab would be nice. Thanks. Jon
Civilian - theres a deal on FB Marketplace Jim Tillson in CT is selling three new SIMs cab for $2500 ea Log into Facebook
Then a golf cart cover on my B21 - works well.
   / Opinions - Replace B21 TLB with this B26 TLB? #45
No, I had 3rd Function. NH has a lot of rocks. Hit too many frozen on ground rocks along where I plow. Lucky the L39 is stout. Have engine turned up to low 40's in HP and that helps a lot.
   / Opinions - Replace B21 TLB with this B26 TLB? #46
Yes I know about those invisible rocks under the snow! I don't see any trip springs on that plow, but I see you have added gussets to the back side?
This is my first season with my front plow, and I am glad it has the trip springs - ran into a pavement curb and plow just rolled over on the springs instead of hammering the loader arms or plow. I have ran into rocks etc, when i use the front bucket but never damaged the machine - these TLB's are tough with a stout frame
   / Opinions - Replace B21 TLB with this B26 TLB? #48
........these TLB's are tough with a stout frame
That is what I ike about the B26. Even better would be an easy way for a front snowblower.
And thanks Carl for the lead on the Sims cabs. Jon
   / Opinions - Replace B21 TLB with this B26 TLB? #49
Plow has a trip edge with 4 spring It is an old Fisher commercial duty plow.
2023 Kubota L6060HST Compact Utility Tractor (A56435)
2023 Kubota...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
PALLET OF CHAINSAW PARTS (A58374)
PALLET OF CHAINSAW...
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2014 DRAGON 130...
2007 Mercedes Benz S550 (A56859)
2007 Mercedes Benz...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
