Opinions - Replace B21 TLB with this B26 TLB?
   / Opinions - Replace B21 TLB with this B26 TLB? #41
Finally got the new cylinder - took 16 days via usps to get here. Its an oem cylinder so fit very well
View attachment 2151544View attachment 2151544
Also it’s winter and a good time to get the leaking piston on the backhoe stabilizer repaired - Kubota wanted $100 for seal kit - e-parts had them for 40 so got two.
My $50 Plow with $1,500 worth of weld metal and $1,000 in mods and maintenance!
Nice new older plow - I used mine this week - worked great - Hyd angle works well. Not sure what you mean by $1500 in metal and 1K in mods tho? Was that for the third function or?
   / Opinions - Replace B21 TLB with this B26 TLB? #43
@Mike, what brand of cab do you have on the L39? Or is that diy? I have the B26, and at times having a cab would be nice. Thanks. Jon
Civilian - theres a deal on FB Marketplace Jim Tillson in CT is selling three new SIMs cab for $2500 ea Log into Facebook
Then a golf cart cover on my B21 - works well.
   / Opinions - Replace B21 TLB with this B26 TLB? #45
No, I had 3rd Function. NH has a lot of rocks. Hit too many frozen on ground rocks along where I plow. Lucky the L39 is stout. Have engine turned up to low 40's in HP and that helps a lot.
   / Opinions - Replace B21 TLB with this B26 TLB? #46
Yes I know about those invisible rocks under the snow! I don't see any trip springs on that plow, but I see you have added gussets to the back side?
This is my first season with my front plow, and I am glad it has the trip springs - ran into a pavement curb and plow just rolled over on the springs instead of hammering the loader arms or plow. I have ran into rocks etc, when i use the front bucket but never damaged the machine - these TLB's are tough with a stout frame
   / Opinions - Replace B21 TLB with this B26 TLB? #48
........these TLB's are tough with a stout frame
That is what I ike about the B26. Even better would be an easy way for a front snowblower.
And thanks Carl for the lead on the Sims cabs. Jon
   / Opinions - Replace B21 TLB with this B26 TLB? #49
Plow has a trip edge with 4 spring It is an old Fisher commercial duty plow.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
LIGHT TOWER (A56857)
John Deere 4510 (A53317)
John Deere 4510...
VINTAGE JOHNSON OUTBOARD MOTOR (A58374)
VINTAGE JOHNSON...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
GALVANIZED MILK CAN (A58374)
GALVANIZED MILK...
