Opening up a spring with a track-hoe
   / Opening up a spring with a track-hoe #91
I forgot the lid.
How about for now just a piece of plywood with a rock on it till you find something better. Keeping the falling leaves and branches out will give you a better idea of what is happening in the bottom.
Ron
Ahhh, the pressure of threatening rising water messing up the progress is over - let it fill.
Ron the TBN bridge is exactly the same.
I will put spring pond update photos as I do improvements or the water level gets to the spillway, which ever comes first.:D
The rest of this week will be volunteer work as we turn a cow field into a dining room to feed fried catfish to 1200 hungry people for the annual local VFD fundraiser. Yes - people do come out in over 100 degree temps to eat our fish & more. (We will have water cooling fans.)
Temp now - 105
Here is a teaser pic of the paver drive. I'll start another thread in two weeks under the projects forum.
   / Opening up a spring with a track-hoe #93
Any ideas for a lid (32")?
Don, I'd get a 10' long treated 2x12 and cut it into 3 equal pieces. Then, I'd put those pieces over the culvert and use "L" brackets to bolt to the culvert and the outer two 2x12 pieces. Then use hinges for the center piece so you can open it up and look inside. This will give you a 12" x 32" slot to work in. If you need the whole space, I'd use flat iron to bolt the pieces together in a rigid frame and then hinge them to the culvert so the whole top can be lifted.
See small diagram below.
   / Opening up a spring with a track-hoe #94
Don, I'm a bit confused when looking at your place with satellite view. I think the pond you are working on is the one at "Here >" in the photo below. However, I don't remember this big pond at the rear marked "or this >." Is that a new pond in the back? It looks like it has not been there very long and I don't remember seeing it when we toured your place.
   / Opening up a spring with a track-hoe #95
Jim,
I'd guess it is the OR THIS> if you compare the tree line to his eye level pictures.
You can even see his 2 foot ground water control wall. The CIA must be watching close as that would be really recent.
Ron
Neither Jim.
You see that square pond bottom center. Thats not it either but the berms divert surface water to that pond and it's about 1/2 inch northwest of it. There is a triangle (white) angling to the fence line that is the berm. All the ponds are down to the last 2-4 feet of water and drying fast. All the ponds were here during the bridge project. The big pond dam in the back is the one Eddiewalker took a group on a trailer ride. The "here" is a small "frog" pond that has dried up a month ago.
edit: The red square is the spring pond.
   / Opening up a spring with a track-hoe #97
Aha! There it is along the tree line.:thumbsup:
   / Opening up a spring with a track-hoe #98
Neither Jim.
Don,
So were is the bridge in the photo? I am almost through reading the bridge project.
hugs, Brandi
That's it Jim. On the next google update you will see the white rock around the spring.
The bridge is about 200' from the north fence line. In Jim's map if you follow the gully north from the "or this". It's in the trees next to the open field. When the "or this" pond is full water is under the bridge.
(I know Eddie likes to name his ponds, now I have a name for the back pond: "Orthis")
   / Opening up a spring with a track-hoe #100
I expect to see a name plaque near Orthis Pond soon with me credited with naming it. Woohoo!;):laughing:
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
