Open Center vs Closed Center
   / Open Center vs Closed Center #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
How do I determine what design hydraulic system is on my tractor? It's a Kubota M7060 HDC12.
   / Open Center vs Closed Center #2
open center........
   / Open Center vs Closed Center #4
X3 open center. Majority of tractors have open center hyd's because open center hyd system is less expensive to build & less complex to diagnose if problems arise.
   / Open Center vs Closed Center #5
Ditto on that. Closed center systems require all manner of gismos and whatnots. If the pump is pumping, the oil has to go somewhere. :laughing:
   / Open Center vs Closed Center #6
Tractordata.com will tell you. All replies are same too :thumbsup:
   / Open Center vs Closed Center #7
If JD closed center hyd system is operating correctly when stand-by pressure is attained with no internal/external leaks hyd pump shaft continues to rotate but pistons are forced away from shaft by pump crankcase pressure therefore causing hyd pump to stop pumping oil
   / Open Center vs Closed Center #8
Yeah, that type of pump falls into the "gizmo" category. ;)
   / Open Center vs Closed Center #9
That type of pump set John Deere apart from the rest of the Ag Equipment industry and was a major factor of the company's meteoric rise to the position of North American leader which it has maintained for about 6 decades.
   / Open Center vs Closed Center #10
Tinhack
Just because the CC pump has a stroke control valve & inlet/outlet valves doesn't classify it as "gizmo" category to me. But I understand how a closed center hyd system was designed to function. My JD 4255 which has a similar CC hyd pump that I've owned since Feb. '93 has over 11,500 hrs on original(untouched) hyd pump that I could purchase a ""new hyd pump"" for a little over $500. Can you purchase a new hyd pump for either one of the tractors for $500? I'll bet it can't happen.
Jim
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
2012 Scion Xb SUV (A51694)
2012 Scion Xb SUV...
2017 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
