Open center hydraulics questions
/ Open center hydraulics questions #1
rtm038
New Jersey
Is the return line on an open-center system pressurized?
/ Open center hydraulics questions #2
No, as long as the return flow has direct path to tank with no restrictions. A return filter could produce some pressure.
In a valve with a PB port, and it is not being used, the fluid from the work ports is mixed with main fluid and returned to tank. If you use the PB port, the main fluid flows out the PB port and to another valve. With the PB sleeve installed, the fluid from the cylinders/motors flows out the tank port, only when they are being used.
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2020 BOBCAT T650 SKID STEER (A62129)
2020 BOBCAT T650...
2004 Subaru Impreza AWD Sedan. (A61569)
2004 Subaru...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
