Oops
/ Oops
You could tighten the top link to take that slack out but the cut isn't as good. I just set the draft height with the left arms, canted slightly forward by lowering the tail wheel so I only cut the grass once, and leave that top link connection pretty loose. It seems to cut best that way and tracks over slopes well.
/ Oops
Yesterday's adventure, on the highway, at 60MPH, towing the tractor, of course...
Been a rough week.
GW, that's the "standard" top link connection that BushHog (brand) has used for years. The cut height is entirely controlled by the 3 pt arm height and the tail wheel. As STx said, the swivel connection just allows the hog to follow land contours better without the top link lifting the tail wheel so frequently. Bushhog's instructions for it are to set the top link length so that the "swivel" part cants forward at about a 45deg angle when on flat, level ground. Works about the same as having a section of chain in the top link. Neither is perfect, but works pretty good.
- Jay
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
Mack T/A Day Cab Truck Tractor (A64556)
Mack T/A Day Cab...
2013 Keystone RV Trailer (A64557)
2013 Keystone RV...
