Oops
/ Oops
You could tighten the top link to take that slack out but the cut isn't as good. I just set the draft height with the left arms, canted slightly forward by lowering the tail wheel so I only cut the grass once, and leave that top link connection pretty loose. It seems to cut best that way and tracks over slopes well.
/ Oops
Yesterday's adventure, on the highway, at 60MPH, towing the tractor, of course...
Been a rough week.
GW, that's the "standard" top link connection that BushHog (brand) has used for years. The cut height is entirely controlled by the 3 pt arm height and the tail wheel. As STx said, the swivel connection just allows the hog to follow land contours better without the top link lifting the tail wheel so frequently. Bushhog's instructions for it are to set the top link length so that the "swivel" part cants forward at about a 45deg angle when on flat, level ground. Works about the same as having a section of chain in the top link. Neither is perfect, but works pretty good.
- Jay
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
Bush Hog 286 3-Pt Rotary Mower (A66408)
Bush Hog 286 3-Pt...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2022 EZ-GO ELITE...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
