One tractor with mower and loader, or separate tractor and mower?
   / One tractor with mower and loader, or separate tractor and mower? #31
Awesome pic
   / One tractor with mower and loader, or separate tractor and mower? #32
That's where you're wrong. I could cut it twice as fast on my ZTR.
Likely you could cut more than twice as fast especially if there are lots of bushes and trees to mow around. I cut my 6 acres in about 2.5 hours and I have more than 100 obstacles to mow around. About an acre of it has only 4 trees and it only takes me about 15 minutes to mow it with a 52" mower deck.
   / One tractor with mower and loader, or separate tractor and mower? #33
You're probably right. My yard is about 2 acres and I can mow and weedeat it in 40 minutes.
   / One tractor with mower and loader, or separate tractor and mower? #34
I bought 3 of the best lawn mowers around, all I had todo is install fence for them. My cows keep the grass at a nice height.
   / One tractor with mower and loader, or separate tractor and mower? #35
I would go with one machine. I would start out with a SCUT or a small compact. Then later on if you get the money you can get a lager tractor for bigger jobs and keep the scut for the small stuff and mowing. It sounds like you already know how useful a SCUT is.
I think if you go with a used ZTR and larger tractor, the tractor will be too heavy for lawn care.
   / One tractor with mower and loader, or separate tractor and mower? #36
I do all the things with my tractor that OP needs and more on our 82ac. Mow yard, maintain drives, clean / build ditches, grade / clear land, etc but don't have hay bales to move. Don't know the used market in his area, but don't see why it can't be done with 1 machine if his budget can cover it.
   / One tractor with mower and loader, or separate tractor and mower? #37
My conclusion... a tractor isn't good for mowing, and a mower isn't good for tractoring. If you can swing it get one of each.
   / One tractor with mower and loader, or separate tractor and mower? #38
SRS what did you end up doing..? Curious. This is the time to buy a used ZTR.. you will get a killer deal.
Here's a great mower right in your back yard.. if it is still there.
Toro ZTR Timecutter Zero Turn Lawn Mower
I purchased a used Ford tractor for $2800, and I am working on picking up a zero turn for around $2500-$3000. The tractor isnt perfect, and the mower wont be perfect, but perhaps it will do a better job separately than one machine together. I've already had that option at one time, and found it to not do either task well.
   / One tractor with mower and loader, or separate tractor and mower? #40
I'm in Raleigh, can probably help you out on a mower at a good price and leave more for a tractor budget.
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
2012 International 4300 Reefer Truck (A56438)
2012 International...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
