One tractor with mower and loader, or separate tractor and mower?
   / One tractor with mower and loader, or separate tractor and mower? #31
Awesome pic
   / One tractor with mower and loader, or separate tractor and mower? #32
That's where you're wrong. I could cut it twice as fast on my ZTR.
Likely you could cut more than twice as fast especially if there are lots of bushes and trees to mow around. I cut my 6 acres in about 2.5 hours and I have more than 100 obstacles to mow around. About an acre of it has only 4 trees and it only takes me about 15 minutes to mow it with a 52" mower deck.
   / One tractor with mower and loader, or separate tractor and mower? #33
You're probably right. My yard is about 2 acres and I can mow and weedeat it in 40 minutes.
   / One tractor with mower and loader, or separate tractor and mower? #34
I bought 3 of the best lawn mowers around, all I had todo is install fence for them. My cows keep the grass at a nice height.
   / One tractor with mower and loader, or separate tractor and mower? #35
I would go with one machine. I would start out with a SCUT or a small compact. Then later on if you get the money you can get a lager tractor for bigger jobs and keep the scut for the small stuff and mowing. It sounds like you already know how useful a SCUT is.
I think if you go with a used ZTR and larger tractor, the tractor will be too heavy for lawn care.
   / One tractor with mower and loader, or separate tractor and mower? #36
I do all the things with my tractor that OP needs and more on our 82ac. Mow yard, maintain drives, clean / build ditches, grade / clear land, etc but don't have hay bales to move. Don't know the used market in his area, but don't see why it can't be done with 1 machine if his budget can cover it.
   / One tractor with mower and loader, or separate tractor and mower? #37
My conclusion... a tractor isn't good for mowing, and a mower isn't good for tractoring. If you can swing it get one of each.
   / One tractor with mower and loader, or separate tractor and mower? #38
SRS what did you end up doing..? Curious. This is the time to buy a used ZTR.. you will get a killer deal.
Here's a great mower right in your back yard.. if it is still there.
Toro ZTR Timecutter Zero Turn Lawn Mower
I purchased a used Ford tractor for $2800, and I am working on picking up a zero turn for around $2500-$3000. The tractor isnt perfect, and the mower wont be perfect, but perhaps it will do a better job separately than one machine together. I've already had that option at one time, and found it to not do either task well.
   / One tractor with mower and loader, or separate tractor and mower? #40
I'm in Raleigh, can probably help you out on a mower at a good price and leave more for a tractor budget.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
