One stuck Boomer!!!
/ One stuck Boomer!!! #21
A come-a-long is a good idea. But I think you have a good excuse for buying a winch.
/ One stuck Boomer!!! #22
Here is a couple idea's...
Call a wrecker. The $50 or so would be small for getting your tractor out
Or, get a come-along. For $25-35, you would have something you could use again.
Get a Hi-Lift jack. For the $50, you could use it to winch, after you use it to jack/lift the tires a bit and block them up.
The drawbar is partially exposed. Get some planks under there, and a jack(you may need to dig it out a little to make room for the jack). Jack it up, and put blocks or planks under the tires. Repeat until it is high enough to easily get you out. Add those extra blocks; it would be bad to get it up just a little, go 2", and be just as stuck again.
I've put full size 3/4 ton 4x4's to the frame in the mud. Dig, dig some more, and jack/block it up.
/ One stuck Boomer!!! #23
In my area, a tractor stuck a ways off the road like this looks. A wrecker charges between 150 to 200 dollars. I know this from neighbors who drive on their newly purchased lots when it's too wet to get out.
Robert, I woould love to have another tractor come in and help out, but a tow truck would have to have a '500 cable to help out. Don't know if you can see that from the pics or not.
thanks
gary
/ One stuck Boomer!!! #25
Hi.. I'm new to this site.. but I have 575 hrs on my TC35D w/ SS.. 17LA FEL.. rubber filled front.. liquid filled back.. w/ double rear wheel weights (Ag tires). I get stuck all the time.. and w/ the 2-3 feet of snow we received in Thurmont, MD last week.. in 3 days of digging out.. I got stuck at least twice. My trick is to use the FEL to help crawl the tractor out.. extend the FEL at the level position and lower the bucket until you are almost picking the front wheels off the ground.. lock in 4wd.. power up to 25 hundred rpm's.. step on the differential lock. Now use the dumping hydraulics to pull & lift while lightly pushing the forward hydro pedal. It takes some coordination & timing.. but I can climb up & out a creek bank using this method. Unless you're pushing mud w/ your grill.. you should be able to crawl your way out.. if you can't go uphill.. try pushing yourself backwards w/ the FEL. Check out http://home.earthlink.net/~kensfarm/index.html to see pictures.
/ One stuck Boomer!!! #26
Very nice. Yep, I was down in a wet hole and got out. The hole wqas from where I had to dig about 2 feet down to loosen the roots of tree I was pushing over. Finally finished pushing and wound up at bottom of hole. Lots of mud. I worked it back and fourth with fel, wheels, etc, using some right and left steering as well. Finally pulled myself out. But the fel just kind of sloshes the mud around if you can't get something hard under it. I had to reach up and pull some harder (less muddy) dirt down. Took about 30 minutes.
/ One stuck Boomer!!! #27
I agree with RobertN. A high lift jack will get you out. Put some planks under the draw bar, jack it up, put logs, rocks, or whatever you have under the tires and let the jack down. Repeat this until you have the rear tires up out of the hole. Use the FEL or jack to do the same with the front tires. Then, fill the trenches with logs, rocks or whatever. You'll have much better luck getting unstuck going downhill. Once it's out find another route up the hill. If you can't get it out that way, use the high lift jack as a come along. It's slow, but it will pull pretty hard. I got a full size Blazer unstuck that way and it was buried right up to the frame.
/ One stuck Boomer!!! #28
I've used that method to push myself backwards, but never forwards. Hmm. Could you chain to the tree and to the lowered bucket, then raise the bucket all the way up, pulling you forward while you drive forward. Set the bucket down to slack the chain, re-tighten and repeat. Might take a while, but might get you there a foot at a time.
/ One stuck Boomer!!! #29
</font><font color="blue" class="small">( Hi.. I'm new to this site.. )</font>
Oh, I almost forgot, Welcome to TBN! /forums/images/graemlins/laugh.gif
/ One stuck Boomer!!! #30
One other thing that is true of the tractors from years ago (at least those that I've used, 8n/9n, JD B, etc) is that they do not have a low gearing as some of the CUTs today. This matters when you're chaining something to the rear wheels.
I did this with a Ford 1700 a couple times in the woods. With that thing, at 1000RPM, in R-1 or 1-1, the wheels turned so slowly that you could monitor the whole process easily (without riding the clutch).
That said, I wouldn't recommend it because one of the times that I did it, I bent the rim/wheel center piece (dish?). The Ford dealer heated it hot, put it underneath the bucket of a BIG wheel loader, and then beat it with a 15lb sledge to straighten it. Never was perfect after that /forums/images/graemlins/smile.gif
-Chris
/ One stuck Boomer!!! #31
With the limitations on where you can get a wrecker too, here is another idea. Contact a local 4x4 club or repair shop. You may be able to get a Jeep or Pickup with a winch to come over for a donation to thier club.
Otherwise... I would go back to the jack. You could even use the floor jack from you garage, so it does not cost you anything. Dig out under the drawbar so you can get a plank under there, and place the jack on the plank. Jack it up a little, and place boards under those tires. Jack it a little more, and more boards under the tires.
No matter what, it will take time, and be a pain. I've spent 2-3 hours getting unstuck that way.
Good luck either way!
/ One stuck Boomer!!! #32
RobertN - </font><font color="blue" class="small">( With the limitations on where you can get a wrecker too, here is another idea. Contact a local 4x4 club or repair shop. You may be able to get a Jeep or Pickup with a winch to come over for a donation to thier club.)</font>
I was thinking the same thing. Here's a link that might help:
http://www.sfwda.org/clubs.html#NC
here's a picture of our regional radar...more rain/sleet/snow /forums/images/graemlins/crazy.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/frown.gif
/ One stuck Boomer!!! #34
One more idea...about 2' at a time .....Roll the bucket to the full dump position...put the chain hook on the blade of the bucket and take the chain around back of the bucket and over the top. Now if you have a stationary object or even better, a good tree out front, you can move your tractor forward by rolling your bucket back to the loaded or level position...It's only about 2' each time but the two bucket cylinders have a lot of power..Keep your bucket as low as you can and still roll it but I have used this manuver in and embarassing moment and .......It worked...
Gene
/ One stuck Boomer!!! #35
Gary,
I would call a local wrecker. You might be supprised the length of cable the local guy might have access to.
The good news is that your tractor is a very light load for the wrecker. The cost might not be to bad either.
I have bit the bullet on three ocasions in recent memory:
1) Bobcat with one set of tires buried beyond view. ~$50
2) Lime truck. 50% my problem. Expensive since it weighted ~40,000-50,000 lbs.
3) Backhoe. Not really my problem since a contractor messed up and had to pay a wrecker to pull him out. I just watched and hoped they did not tear up anything else.
It happens. Sometimes its just best to call in the help before it gets any worse.
Fred
/ One stuck Boomer!!! #36
phred, must have been one really bad area if a backhoe couldn't self extricate itself. Wish I could see a picture. Bill C
/ One stuck Boomer!!! #37
<font color="blue"> I would call a local wrecker. You might be supprised the length of cable the local guy might have access to. </font>
When I got my 4 x 4 Chevy S10 pickup truck (my first truck and my first 4 x 4) stuck in my own field ("4 x 4 can go anywhere, right?" attitude), I had to call a wrecker. The closest place he could get was our driveway that was at least 250' from my truck, which was buried up to the axles. He used the cable on the upper arm off the back of the truck.
So I agree with others who have recommended this. Pace off the distance from your tractor to the closest place a wrecker could get and call a towing service to see how long the cable is on their vehicles.
/ One stuck Boomer!!! #38
A fellow told me today that if I ever get my tractor stuck to put lime on the wheels and that would help get me unstuck. Anybody heard of doing that? Can anyone confirm or dispute that idea?
/ One stuck Boomer!!! #39
I do know that quantities of lime will tighten up muddy soil, but I would doubt that you could get it to tighten up enough to allow a tractor to climb up and out. You'd have to break up and mix in the lime along the escape route also.
Now if you have limestone slabs..... /forums/images/graemlins/tongue.gif
/ One stuck Boomer!!! #40
So it might work if I was a "little stuck" but probably not when "big stuck" like Gary?
2013 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2013 FORD F150...
2011 HUTCHINSON CRUDE TRAILER (A67714)
2011 HUTCHINSON...
2021 Bobcat T66 Compact Track Loader Skid Steer (A66734)
2021 Bobcat T66...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64557)
2019 Cub Cadet...
