one slow cylinder
   / one slow cylinder #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i have a bobcat quick att. on my loader ...today i took off the forks and was lineing up the bucket and i noticed on of the dump cylinders was real slow....it was not matching up with the other ,,,any ideas on what this could be ??? thanks for the help bruce
   / one slow cylinder #2
When you have 2 cylinders connected hydraulically but not mechanically, one will almost always ( like 99% of the time) lag behind the other. This is perfectly normal and nothing to be concerned with.
There are so many factors, hose length, cylinders not being exactly the same, basically a hundred variables. As a matter of fact, I don't know if I ever saw 2 cylinders connected hydraulically but not mechanically extend and retract the same.
   / one slow cylinder
thanks for the help.... it may have done this all along ...this my be the first time i noticed it,,,,,,thanks bruce
   / one slow cylinder #4
I never have either. I would call this perfectly normal behavior.
   / one slow cylinder #5
Most loader manufacturers have figured out it is a lot handier for the operator when the two sides of the QA unit are tied together mechanically.
   / one slow cylinder #6
My forklift's tilt cylinders are like that. If you watch, one side is always ahead of the other. If you look, the one that extends/retracts faster probably is closer to the valve/supply or has a shorter hose.
   / one slow cylinder #7
Is this with the mast on the truck? If so, your rod ends need to be adjusted. Over time, you can damage the mast bushings.
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
