Onboard Hydraulic Grenade
/ Onboard Hydraulic Grenade
john_bud said:
It sounds like you may have hooked the loader valve up backwards.
I hope so!
The relief valve is always (far as I know) on the inlet side. If you hooked it up with the "IN" hose going to the "OUT" of the valve, then when you operate the controls, you are isolating the relief from the fluid. Any over pressure can't be relieved and the weak spot is located with much fan fare and excitement.
I'll be posting pictures in a few minutes. Hopefully you can comfirm that I've gotten it wrong :)
A second thought, your selector valve. If you operate the selector valve while the tractor is running, it may dead head the pump. Instantly killing it. Don't know if that is the case or not here. Just something to beware of.
john_bud, that is a very interesting thought. I'll be testing the selector valve to see if it blocks incoming flow at any point in its travel. I don't need any more ways to kill my pump :)
Your hyd diagram does not include the BH circuit. There may be a relationship there, don't know for sure.
No, the backhoe is a closed system with its own pump, tank, fluid, etc. ...And it's sitting under a tarp behind the garage.
That was actually the motivator to this whole catastrophe: I needed to remove the backhoe to install a snow blade on the rear, but didn't have any way to power my loader without it.
Also, I got the impression that you put the pump on replacing the function of a PTO pump. Did I read that right? If so, the fluid may be too thick for the pump. Check with the pump mfg to be sure. Over pressure situations can occur even with an operable relief valve if the viscosity is too high. Basically, the fluid can't get out the relief port fast enough to drop the pressure. Again, may not have a bearing on the case. But good to know.
No problem there, this is the pump Kubota hung on the side of my motor 30 years ago. And it's pumping the same 80W gear oil that it's been pumping since the beginning, including all winter last year.
My meddling in this system is the diversion of fluid away from the 3pt hitch lifter (the only use for that pump) and into the FEL.
Thanks very much for your help.
/chris
Okay, more pictures of my bad plumbing for your entertainment :)
Here's a shot of the pressure line entering my loader control valve (selector valve barely visible below):
And here's the return to the gearbox side (obvious from the heater hose and clamp, I think):
Note that it says "OUT" on this side. That's why I hooked it up this way. Seemed reasonable at the time...
That thing on the right, closest to "OUT" is what I've been assuming is a pressure relief valve.
Here it is with the cap removed:
I'm hoping for some opinions:
Did I hook up the valve backwards?
Is that thing a pressure relief valve?
I didn't take it apart any further than shown because I didn't want to risk screwing anything up. That cap/locknut/screw setup looks very adjust-y.
Thanks for all of the feedback so far!
/chris
/ Onboard Hydraulic Grenade #23
I'll let the tractor guys here comment on the hose positioning as they are far more experienced than I. As far as hoses bursting, all hoses have a 4:1 safety factor. A hose rated for 4,000 psi has a burst rating of 16,000 psi. Hoses also have some give, pump castings have no give.
/ Onboard Hydraulic Grenade #24
Chris,
Before the pump gave it up. Was there any change or fluctuation in the RPM at all when you were raising or dumping the loader without a load on it when you let off of the handle? If there was, did it go up, down etc and about how much? I hope that wasn't to mudded.
(Raising the loader empty. Let off the handle. What type of movement in the RPM when let off?)
/ Onboard Hydraulic Grenade #25
I think you have it hooked up backwards. On everything I've seen, the relief valve in on the input block, and when activated diverts to the output. The puzzling thing is the "out" on the block. I can't explain that.
If at all possible, I'd put a gauge on the system after the pump and before anything else. Then very gingerly activate your hydraulics to test it. Your relief valve may just need adjusting too. It sounds like until now the backhoe relief valve has been doing all the work. If you note the position of the relief valve screw, then back it off counting the number of turns or half turns, you will be able to get back where you started.
/ Onboard Hydraulic Grenade #26
Chris,
As Hayden said, it's not a standard valve flow path. Not to say it's wrong. You may have to take off the inlet and outlet blocks and post pictures of their inner surfaces. Is there any marking of "in" on the other side?
I'm not an expert, there are real experts that deal with this daily. Maybe one of them can chime in?
Here's a link to a typical loader valve.
Surplus Center Item Detail
The left most control handle is for the boom and has the float spool. The right most handle is for the bucket curl. The Right most side has a large hex plug. That's plugging the power beyond port. Next to it, is the outlet port for fluid back to the sump. The LEFT side is the inlet side and that little stub thing sticking out looking almost like a 3rd spool, is where you would adjust the relief valve. That's typical standard common what you see every day when you look at most tractors.
Hope that helps.
jb
/ Onboard Hydraulic Grenade #27
The thing with the screw must be either a relief valve or flow control. I'd bet it is the relief. You could take it off and see how it is ported. That should tell you.
In any case, when it is fixed, I'd switch to all UDT. There must be a reasson kubota changed it. Maybe cold WX. As John Bud mentioned, viscosity can cause extreme pressures.
First though, you have to figure out if it is backwards. Expert opinions?
JerryG said:
Chris,
I didn't notice any change in the RPM. The motor was probably turning around 1400 (I don't have a tach) at the time, but was under (pretty much) no load.
I think my hand was still on the levers (one forward, one back) at the moment it broke.
Looking carefully at the pictures of the other side (I haven't been back out to the garage yet) I found this:
I think both sides might say "OUT".
Maybe both ends of valve are made from the same casting?
If I switched my hoses around, I'd have the inlet hose on the unmarked end of the opposite casting, and the outlet hose right here where it appears to say "OUT" in the photo above. That would put both the relief valve and the tank return next to an "OUT", which makes sense.
/chris
/ Onboard Hydraulic Grenade #30
Good pictures are always helpful. It looks like both sides of that unit can be removed and swapped. So you could remove the relief valve and put it on the other side where I think it should be. Maybe not all valves are built the same but mine flows from left to right with the inlet on the left and the outlet on the right. Yours looks like it's made to allow the stacking of more spools. I think someone hit the nail on the head when they said the hoe relief valve was doing all the work. I have pics of the setup on my b6100 on this thread: http://www.tractorbynet.com/forums/kubota-owning-operating/70830-b6100-picture-3.html
Can't do that. The side I'm currently using as "IN" is only tapped on one end. The other end is a closed casting:
Almost certainly that's the case, but I'm not clear on the reason. I'd been assuming that it was because the hoe's relief was set a few PSI lower than the loader's.
But I'm still not positive that:
  1. I have a relief valve at all (What is that thing?)
  2. If it is a relief valve, that it's functioning correctly
Hopefully somebody will chime in to tell me that it is a relief valve, and that I'm just a knucklehead for hooking it up backwards. :)
/chris
/ Onboard Hydraulic Grenade #32
You mentioned it looked adjust-y - try turning the screw in and see if it's already bottomed. Then turn it out and see what's in there. If it's spring loaded it won't be huge - just go slow and keep track of the order the parts as they come out. It might be a relief valve - they are sometimes adjustable with shims and/or springs. Some can be adjusted so they don't relieve at all - if it's screwed it down tight that would defeat its function.
/ Onboard Hydraulic Grenade #33
I don't think you get my meaning when I say they look like they can be swapped. The first picture shows your valve setup. The part I outlined in red looks like it could unbolt by removing the 3 nuts and swap with the same piece on the other side. Maybe it's the picture but it looks like there is a gasket there.
Now in looking at mine I see a big difference. I have 1 in hose and 2 out hoses. One comes out of the power beyond and heads back to the block to feed the 3ph. The other dumps right back into the resorvior. You only have one dumping out, maybe it doesn't matter but I figured I'd mention it. Pics below, sorry they don't look quite as nice as yours. I can e-mail you the higher res ones if you like.
Lastly, if you look at the picture I posted in another thread you see that I too have a large bolt thing on the left side. When I took it apart a couple years ago I realized it was not a relief valve, I don't think yours is either: http://www.tractorbynet.com/forums/...d1136338821-b6100-picture-800629-dscf0068.jpg
Thanks very much to everybody who's helped me out so far.
Without you guys, I probably would have put my new (used) pump back into place and blown it up as well!
I finally took apart the adjust-y looking hex thing on my loader valve. Here's what I found inside:
Here's where that came from:
The needle/cone shaped thing on the left seats in the end of this bore:
Straight through that bore, we're connected to what should have been the pump.
When the needle is seated (by spring pressure), it stops fluid from flowing into the hole on the right side of the bore:
That hole leads to what should have been the return-to-sump line.
So, it's pretty clear that
  1. I do have a pressure relief valve
  2. I had it hooked up wrong
Finally, I've followed john_bud's excellent advice, and tested my selector valve to be sure that it doesn't have a closed center behavior midway through its travel, possibly costing me another pump.
I ran some compressed air through it while slowly changing positions. Luckily, it does not behave that way. There's a point midway through its travel where both output selections receive flow.
I was a little worried about getting the pressure relief set correctly, so I counted threads, etc...
But I don't know if it was ever right to begin with. So I plan to set it fairly loose, and tighten until the loader can lift 13 bags of wood pellets.
/chris
/ Onboard Hydraulic Grenade #35
You can get yourself a decent gauge and some adaptor fittings to make up a test kit for under 50 bucks. This way you are certain to get the pressure correct. It just may be the best 50 bucks you ever spent. I'll run thru a quick list of fittings and adaptors that should do most of your pressure tests.
1. Liquid filled 0-3,000 psi gauge.
2. -8, -6, and -4 JIC street run Tee.
3. -8 X -6 JIC reducer.
4. -6 X -4 JIC reducer.
5. 2 wire hose, -4, 2 feet long. -4 female JIC X -4 male JIC. One fitting, -4 female JIC X -4 female NPT. This adapts the fittings to the gauge and lets you position the gauge for visibility. -4 hose is cheap, so if you wanted this longer, do it. You could purchase other fittings as needed, but this would be a good start. Some metal caps and plugs wouldn't be a bad idea either.
Okay, maybe a little more than 50 bucks depending on where you purchase, but in my opinion, much cheaper than another pump.
I've just revisited this thread because I noticed some log activity on my photo server. Someone's followed this thread to my pictures.
...and it turns out that I never posted a post-repair follow up.
It turns out that I installed the valve backwards. My control valve is identical on both sides (both say 'OUT'). ...Except for the pressure release valve. That's only installed on one side.
I mistakenly ran the pressure line to the non-relief side, and the return line to the relief side.
I got a new (used) pump from the fine folks at Pittsburg tractor in TX, swapped the supply and return lines, and was able to move snow all winter without incident.
The onboard pump still doesn't move enough fluid for my taste, but it's usable. My loader is a B219 knockoff with 2" ID cylinders. They're too big, and make the loader slow to operate.
I'd been toying with the idea of replacing the tip cylinders with smaller ones, or ditching one of the tip cylinders and relocating the remaining one to the center of the bucket.
...But I think I'll just watch for a good deal on a joystick loader control with regenerative dump. That should speed things up enough to keep me satisfied.
Thanks for all the help.
/chris
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
Kubota ZD221 48in...
3142 (A63117)
3142 (A63117)
Eagle Weather Vane (A64557)
Eagle Weather Vane...
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
JOHN DEERE 1790 - 12R30" / 23R15" VACUUM PLANTER (A64278)
JOHN DEERE 1790 -...
