Backhoe ? on using backhoe to fell tree
/ ? on using backhoe to fell tree
Thomas: Your right about the base. A couple of these root balls have taken a circumference of dirt 7 to 8 feet wide I would guess, which COULD bring up a hidden dagger up underneath Brutus. As long as the tree is tipping, I still push. Once the tree actually starts to fall on its own volition, I hit reverse to try to minimize any underneath problems AND lower bucket to keep it close to tree as buffer against it coming back. I have noticed though, that by the time I get to this point, the tree would have to defy gravity to come back towards me, meaning it’s REALLY leaning over HARD.
Scruffs: Not too sure anyone wants these dead pine trees as firewood, ALSO, as they are within range of hitting house should they fall in that direction, I don’t know that I want ANYONE dealing with them except me or a logger and unfortunately, the loggers WON’T touch them. /w3tcompact/icons/mad.gif
Twinks: (I just HAD to say it that way /w3tcompact/icons/smile.gif) don’t forget, that I’m not talking about using a B or L-series, but a Brutus /w3tcompact/icons/laugh.gif
Gordon: Repeating clarification that trees are within hitting distance of house, so I’m thinking that Brutus can help insure direction of fall FAR more than just cutting as I CAN’T have them fall on house if AT ALL possible. Now, there are only say 8 to 12 (currently standing) that meet this reality. THOSE are the ones I am most worried about. The others in the woods or fields, I don’t care about and have NO problems just chopping down with my trusty Stihl 044.
Given that the dead trees in reference are within hitting the house distance (with one “medium” one actually having a lean towards house), and that the professional loggers (who BOUGHT them by the way) have decided to LEAVE them thereby putting me in a quandary. What is better? Cause I have to do something...
1. Using saw and be at risk of barber chair or falling limb or other falling on “me” or house
2. Use saw to cut my felling angle and make preliminary final cut to THEN push over with Brutus
3. Use saw to cut my felling angle and push over WITHOUT preliminary final cut
4. Simply bull over with Brutus if tree will go
5. If 4 doesn’t work, loosen up roots and push with Brutus as per origination of thread
Will certainly entertain ANY and ALL ideas, as these dead/dying trees are not going to become any safer.
Another tidbit that may influence some thoughts...these dead pines are in the middle of other trees, primarily 3 to 4 inch poplar/oak or other kind of hardwood that I “prefer” to work around and try to save. If they all get crushed and nobody gets hurt, nor house I can live with that, but in a perfect world, I’d like to save as many of these as I can also by felling pines in quite specific directions, hence, another factor in the logic of using Brutus to push. I’m very willing to sacrifice any that I need to in the name of safety however. I don’t even mind sacrificing Brutus if it means accomplishing the job AND accomplishing it the safest way possible. Obviously I would rather not sacrifice Brutus, but Health and House come FIRST.
Richard
/ ? on using backhoe to fell tree #13
I have played this little game of felling a tree that was too close to the house (and carrying the majority of its weight _over_ the house) and I can tell you guys it is not at all fun. In fact it was one of the most harrowing things I have been involved in and I am including all my stupid tractor moves when I say that. The best idea that I could come up with was to use my pickup as an anchor and get some polypropolene rope (not sure how you spell it or even if that is the right name, it is the white plastic type rope they sell at Wal-Mart) and pull some spring into the rope to influence the tree the way I wanted it to go. I had four seperate lines going to the tree for safety and so I would not exceed the breaking strength of the rope. The ropes were long enough so the truck was not at risk. I had my wife in the truck and told her to step on the gas (but not too hard) when tree started moveing to get it further away from the house when it fell. I then notched the tree and prepared for the festivities. Everything was ready, the chainsaw was running, my wife was in the truck applying just the right amount of gas pedal (it's an automatic) to keep the tension right so I make my cut into the backside of the tree so it will fall and to make a short story long, things started happening WAY TOO FAST. The tree was cracking and started to fall. My wife stepped on the gas exactly as instructed. The tree started falling somewhat sideways. My wife saw what was happening and gave the truck more gas. The truck is a full size Chevy and as I am watching it get pulled a little sideways she really gets in it and all I can think is how much pull can that truck exert on those now way too small looking ropes that looked so big just a second ago. The ropes hold. She pulls hard enough to keep the now sideways falling tree from hitting the house. The tree almost takes out the air conditioning unit next to the house. But it is down and we are safe. My wife is almost freaked out because the tree fell sideways and pulled the truck sideways instead of just falling towards the truck. I am freaked out because in my mind I saw the ropes break and the tree come crashing into the house. But it didn't. Thank God.
This was not the first tree I had ever cut down. I have enough experience to know trees don't always do what you think they will. I have learned a lot about trees and tractoring from this board and I am hopeing that Richard and all of you will learn something from my post about how bad things can get even when the most carefully thought out plan is set into motion, although I still think the elastic rope trick is a good one when you want to infuence the direction of a falling tree. If I did it over again I would use a 20,000 pound rated springy tow rope. Anyway, it still worked for me, but JUST BARELY.
/ ? on using backhoe to fell tree #14
/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gifKubotadriver, we did the same thing at my brother's house this past Spring with a big dead oak tree leaning toward his house, except we had a single 150' strong nylon rope attached to my 3/4 ton Ford pickup. We considered all the possibilities, and were definitely running scared, but that tree had to come down. Fortunately, we had better luck than you and all went smoothly.
Nylon rope has lots of stretch to it. A couple of years ago, we took down a big willow and didn't want it to fall across a fence, so we did the same thing, but had the rope tied to my brother's Kawasaki Mule, and had to run the rope through some brush, so that I couldn't see him or the tree when I got to the end of the rope. He said he would notch the tree, kill the engine on the chain saw, then when I heard the chain saw rev up again to take off because he would be cutting at the same time. I did, and when I heard the tree fall, I took my foot off the accelerator and that rope jerked me and that Mule backwards about 10 feet like a rubber band. If I hadn't had the seat belt on, I'd have probably bit a chunk out of his steering wheel./w3tcompact/icons/laugh.gif
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 11/8/00 11:00 AM.</FONT></P>
/ ? on using backhoe to fell tree #15
Richard,
I like WVBill's plan. The only thing I might do differnt is to add Brutus's backhoe bucket to the tree while making my cuts. I don't think I would add much push, but it takes alot to move a 9000lbs+ TLB.
I do hope you will keep us posted. This is getting better than the soaps.{smile}
Mark..I'll have you know that Brutus has a FULL GIRTH of 16,000 pounds, (ok 15,900+ pounds, I'm adding in a FULL fuel tank)not your svelt 9,000 pound "baby" /w3tcompact/icons/laugh.gif (trying to sound overly indignant and put out!!)/w3tcompact/icons/wink.gif
MarkV...AND ANOTHER THING (do I still sound indignant??) /w3tcompact/icons/wink.gif
Seriously, another thing is the reality of being single personed (as opposed to single handed)
Father and Uncle in laws are ~80+/- and I DON'T want them part of cutting while I'm pushing with hoe or bucket. I also don't want them DRIVING while I'm cutting...Same with my better half...
I can't do both, and I ***REALLY*** don't want to cut a fellig notch, make an "incomplete" felling cut, leaving the tree standing on the hinge while I crawl back into Brutus, hoping/praying that tree chooses to continue to stand and no whisp of wind arises..../w3tcompact/icons/crazy.gif I was going to have a friend out to help out and my better half (or is it SMARTER half??) nixed his help. Said if HE want's to cut his leg off with chain saw, he can cut his OWN trees down. (?)
I'm kinda between the proverbial rock (tree) and a hard place (house) and if there is any life still left in these pines, (thereby giving me SOME element of time) it is leaving daily.
/ ? on using backhoe to fell tree #19
There was a article in the local newspaper just recently.Apparently a man was using his tractor to push over some trees and then cut them up with his chainsaw.The neighbors found him sitting on the seat of his tractor,Dead,and the tree he was pushing over still on top of him!!!! True Story. I can search the papers archive if anyone would like to read it for themselves.Tom
/ ? on using backhoe to fell tree #20
Cutting trees is one of the most dangerous things you can do. As an industry it has one of the highest injury/death rates. It's because trees are big, their fall cannot be reliably cotrolled, and whatever they hit on the way down, they usually win.
I've cut lots of trees (100's) and it still scares the you-know-what out of me, which I consider good.
Here's are my suggested guideline:
1) Don't knock down a tree with a piece of equipment unless it's designed to handle it.
2) Is the machine specifically designed to knowck down trees? If not, don't do it.
3) If the tree falls directly on your machine, right where you are sitting, will it matter? If it will matter, then don't do it.
I had a 100' white pine come down in my yard in a wind storm. It up-rooted a 20' diameter ball. If I had driven close enough with a tractor to push it over, the tractor probably would have been flipped over by the up-rooting ball.
Reading between the line - I think what you are proposing is a bad idea. Only plow down stuff that's clearly smaller than you are.
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Electric Golf Cart (A56859)
Electric Golf Cart...
2011 BIG TEX 40 GOOSENECK (A60736)
2011 BIG TEX 40...
John Deere TX Gator (A60462)
John Deere TX...
UNUSED FUTURE 32"...
