Oil & Fuel On my way to 100
   / On my way to 100 #51
Once again, the Coyote Machine is correct there is a red bullseye.. You have to get your head down and look straight in to the axle, preferably with a flashlight. So today I leveled the tractor with with the 4 x 4 piece of lumber, (level ground in Branson is hard to come by) When I checked the side filler plug on one side the fluid did not come out right away it took a few seconds.. I am thinking there was an air pocket trapped up there. (thank you Milkman636) Then the fluid ball was in the red bullseye (middle) area. I believe I am good at this point. Thanks All.
James K0UA
Double checked my 2011 DS4510 and the axle glass eye on this Kioti model doesn't have the bulls eye, just the ball.
Another maintenance variation, and I am not not sure about the DK manual , but the maintenance schedule on the DS owners manual has the intervals for toe in and front axle pivot mixed up. Toe in adjustment is at 600 hrs (not 200 hrs) and front axle pivot is at 200 hrs (not 600hrs).
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
401 (A52706)
401 (A52706)
