Oliver Crawler Tractor
/ Oliver Crawler Tractor #11
Landis Zimmerman is a friend of mine. He is the foremost expert on Oliver-Cletrac crawlers. He sells new, used and rebuilt parts. He may have a crawler for sale. When a crawler comes out of his shop it is in good condition.
/ Oliver Crawler Tractor #12
I already posted this in another thread the other day, but it was way off the topic that was being discussed and someone might have missed it.
I'm going to post a link to this auction here, in case anyone else is interested...
CURFMAN AUCTION
I'm not able to go to it, so I can't report back on how much they end up selling for.
/ Oliver Crawler Tractor #13
/forums/images/graemlins/confused.gif Was the mower deck attachment visible in the lower left corner of the picture included!!??!! /forums/images/graemlins/smirk.gif
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Oliver Crawler Tractor #14
Hello I had just read what you had to say about the OC3. Well I think that I have found an Oliver OC3 with a 3 point hitch I think a 1952 ? I know you said that they are rare on an OC4. But I think it is an OC3 with PTO and 3 point hitch. It seems to be compleat but just needs the engine rebuilt. It does run but smokes a lot and blow by. Also a question if you do not mind. I had a small Oliver Cletrac sometime ago but I found that they go to fast in the lowest gear. Do you know if the OC3 go's slower or not ? Thank you very much. Loyd....
/ Oliver Crawler Tractor #15
I believe that I have found a 1952 Oliver OC3 PTO with 3 point hitch. I know I read that you said that you had only seen one on the OC4 but I think I have found one. the engine just needs rebuilt but it does run but smokes a lot but it appears to be compleat! One thing I would like to know is this. I had an oliver Cletrac and even in the slowest gear it went to fast for what I wanted. Does anyone know if the OC3 will go slower in the lowest gear ? Thanks. Loyd....
/ Oliver Crawler Tractor #16
Common problem. I have the same issue with no super low gear. There is a homeground solution that I am exploring right now. Look at the aux transmission forum on www.cletrac.org for more info if you are up for the challenge.
Marty
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
