Oliver 1375 - Hydraulic Problem
/ Oliver 1375 - Hydraulic Problem #1
Sfisher12345678
Big Clifty, KY
Kubota & Oliver
Hello! I've got an Oliver 1375. We had to work on the transmission... so, broke the tractor in half (which meant disconnecting hydraulic lines) and now when we reassembled the tractor, the 3 point hitch hydraulic system no longer works. We think we have air or a vacuum in the hydraulic system. We think that our hydraulic pump was working properly before we started working on the transmission...but, we are not 100% sure. Anyhow, just filling the hydraulic reservoir is not working. My question is how do you re-fill and bleed the hydraulic system?
Steve
Big Clifty, KY
TSURUM HSZ3-755 PUMP-1 PHASE INDUCTION PUMP (A62131)
TSURUM HSZ3-755...
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
