Older large tractors
/ Older large tractors #42
"On another ag forum like this, a yonger fellow asked if it would work to hook up his disc conditioner mower behind the 250 hp Cat tracked tractor his dad had so he could use the air conditioner to mow with...."
It seems to me he would flatten an awful lot of hay with those tracks before the mower had a chance to cut it.
Hey! More seat time! Mow, wait 3-4 days for it to stand back up and mow again /forums/images/graemlins/grin.gif
/ Older large tractors #43
Maybe I haven't looked at enough of them but I'd swear some articulates don't have PTO's. I think I've even seen one with no 3 point hitch, just a wall of hydraulic couplers and a HUGE drawbar.
/ Older large tractors #45
Not all 4wd's come with 3pt or pto but it is an option. Even if it doesn't have a pto you can get the hydrualic pto to run off the remotes.
/ Older large tractors #46
When mowing hay you are cutting hay you have not driven over. The only hay you drive over is the first trip around the field. The main concern with the Cat for cutting hay is that on sharp turns it would tear up some ground. If I recall the field the poster was cutting (his name online is racinfarmer) was going to be turned over in the spring anyway so it made no difference. The other issue during that discussion was that disc bines companies recommend you use a cab tractor while mowing in case you hit a stone or a blade breaks. The cab will help to protect you from something flying out of the mower.
/ Older large tractors #47
Don't mean to burst the bubble here but the main reason for the low resale value on articulate tractors is lack of demand from professional full time farmers to buy anything used! They realize that if they are farming they are not in the repair business. They want them up and running without downtime. Cavitation is not in Ford engines but poor quality forgings! They don't have wet sleeves nor dry but are parent bore blocks.
/ Older large tractors #48
Remember when cavitation and special antifreeze was unheard of. Seems it all started with some faulty castings and then got blamed on cavitation.
Egon
/ Older large tractors #49
Robert,
I don't have a hydro swing so I guess I'm stuck in thinking I can only get about 1 ft wider before I'm driving on uncut hay.
I can only think about the hydraulic pto from an engineers perpective and it is so wasteful when transmitting the amount of power a baler needs! Using that cat to bale with is probably costing more per bale is fuel and wear on the machine than you can sell the hay for!
Ken
/ Older large tractors #50
I maybe wrong (and I usually am) but if you hook the disc mower up to the center (drawbar) of that monster you are bound to run over SOME of the hay since the mower was not built to handle that type of width...or be cutting awful narrow passes! /forums/images/graemlins/crazy.gif
And I'd be running over the windrow with the track pulling either my 24T or my round baler if hooked to the center of the track-tor (Did I just coin a new phrase???)
Either way, my fingers were itching to type something. /forums/images/graemlins/grin.gif
/ Older large tractors #51
The Cat he was going to use was not the Big Cat it was the smaller model similar to a JD 8000T so around 200hp. I have farmers here that run 575 NH balers on a MX200 without any problem. In the case of the Cat cutting hay, its width is not a problem as with bigger mowers they have bigger tounges and are designed to work with larger machines. The Cat (I think it was a 45 but don't remember) is actually no wider then a typical wheeled tractor and depending on tires the Cat is narrower then some. The field they were cutting hay was going to be chopped for haylage and not baled. All he used the Cat for was to cut the hay down. I don't remember what other equipment they used for the rest of the job and I don't think it really mattered.
As for the hydraulic PTO, the Cat that was being used came with a 3pt and pto. The people who use hydraulic PTO are the guys who buy an old bareback Artic tractor and want to run the grain cart they already have that has a PTO. Most new Grain carts are all hydraulic so it is very few farmers that would even need to use a hydraulic pto. I didn't say it was efficient but it got the job done for the guys who needed it.
/ Older large tractors #52
Don't worry Robert, we aren't directing our comments at you! /forums/images/graemlins/cool.gif
It would seem to me running 200 horse wheeled tractors would cause a bit of compaction? I know I've read a study on alf-alfa where they showed compaction caused quite a bit of reduction in yeild.
But as you say running what you have is better than nothing at all.
</font><font color="blue" class="small">( I didn't say it was efficient but it got the job done for the guys who needed it. )</font>
/ Older large tractors #53
The one farm has plenty of tractors and some smaller CX series tractors but they always bale with the MX. As for compaction on their farm I don't think it makes a difference anymore. They cut their alfalfa fields and then chop them with a NH FX chopper with a dump cart. The don't feed small squares but do bale the wheat straw and some hay for market. Their fields see a lot of heavy equipment on it and they turn them over every few years as part of their rotation of corn, wheat, alfalfa.
I would love to get some hydraulic powered silage wagons. It would be much easier (relatively) to hook up a couple of hydaulic lines then hooking up a sticky PTO every time I pulled up to the silo.
/ Older large tractors #55
</font><font color="blue" class="small">( What forum is that? I love this site, but I've been trying to find another one which leaned a little more heavily towards larger ag tractors. )</font>
www.ytmag.com does older antique farm equipment real well.
http://talk.newagtalk.com does modern ag pretty well, laid-back folks.
http://talk.agriculture.com is from a farm magazine, and used to be _the_ modern ag discussion place, but it got to be very 'corporate' the past few years, and while it has a lot of traffic yet, it lost all of it's character. In fact, Newagtalk.com was born from disgrundled folks...
www.harvesting.com is a combine parts supplier, and if you can get to the bottom of the page & get to the Case combine discussion page, then click on all discussions, you will find _the_ combine discussion area on the net, from old to new, all brands, very nice folks there. Just hard to find it! /forums/images/graemlins/smile.gif
Those are the places I frequent. Many of the farm magazines have discussion forms, but not as popular as those mentioned. Farm Journal, The Farmer, etc. etc.
As to the Cat on a hay field, Robert covered it very well. It is a rubber-tracked ag machine, & they are frequntly spaced on wide tracks, can straddle anywhere from 2 - 4 30 inch rows, not sure if the one in question was set wide or narrow, but a swing conditioner would accomidate it.
I'm the type of person that much prefers being in the great outdoors anything it is nice enough to plant or cut hay (mind you I love my cabs for tillage & such in cold weather...) so I'd set a screen on the open station tractor fender & have a lot more fun mowing grass a lot cheaper & less stress on the land, but to each their own.
Just had that youthful attitude in the message, thought it was funny actually. /forums/images/graemlins/smile.gif
--->Paul
/ Older large tractors #56
I agree, I love to be in the open station of the TN but when baling or discing I would much rather use a cab and watch the dust fly by the windows and not thru the station /forums/images/graemlins/crazy.gif
/ Older large tractors #57
Here is one that is not that old and right now is a very good price. JD on ebay
</font><font color="blue" class="small">( Here is one that is not that old and right now is a very good price. JD on ebay )</font>
Thanks for the link.
That to me seems like a good buy. The kind of tractor I was trying to get at when I started this thread. I know a local guy who farms around 2000 acres (not entirely sure, he rents a lot of land and is constantly changing) and has a JD like that. I *think* it's a bit smaller though, 8440 if I'm not mistaken?
Anyway, he uses that tractor a lot and it see's some heavy work on the disc ripper. He's rebuilding the motor this winter after years of good use and having it bumped up subsantially (to around 240 - 250hp). He has no problem getting parts at a reasonable price.
/ Older large tractors #60
Robert_in_NY said:
Most of them will need a major overhaul which will cost at least $10k and finding parts for most of them is not easy as most of the companies are no longer in business like they use to be. Massey Ferguson, Allis Chalmers, White, Oliver and Minneapolis Moline are part of Agco now which runs the MF line as a AgcoStar tractor. All the rest are dead and gone and parts are hard to find. John Deere has a lot of aftermarket companies making parts so getting parts for a 30 or 40 series JD is not too bad but isn't cheap either. The old Versatiles are gone as Ford bought them and now Buhler owns them so getting parts would be fun. Steiger was bought by Case-IH and is now owned by CNH but if trying finding parts for a old Panther you had better know of some good used parts dealers. For the money you would be better off geting a 150hp late 90's MFWD tractor and having something you could get parts for and count on when planting season comes up.
Must be the area , All my parts come off the shelf at case or ford and the beauty of steiger or versatile is you can source parts from Cummins , Fuller , Rockwell or whatever your tractor is made of.
And there is a LOT of cheap good ones around .
2022 TEXAS PRIDE GOOSNECK (A65643)
2022 TEXAS PRIDE...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
John Deere 6155R (A64126)
John Deere 6155R...
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
