Old Square Bailer?
   / Old Square Bailer?
Heres a link to one on TRACTOR SHED that look real similar and sold for $500.
Used Farm Tractors for Sale - Hay Press
It would make a nice project.
Rich
It looks similar, except this model looks to attach to a drawbar via a fixed tounge and has 2 wheels instead of 4. It has more modern rims that had airfilled rubber tires on them that are rotted or burned off.
   / Old Square Bailer? #12
The one I used was made by Lilliston Corporation in Albany, Georgia. Lilliston made some of the first peanut pickers (stationary combines) and related equipment used in the south. Long Manufacturing Company also made them.
Our Lilliston Hay baler was similar to the one Rich referenced. It had a one-cylinder water cooled International Harvester motor with an internal gear reduction that ran about 1000 rpm at best. The motor had an enormous exposed flywheel. It was designed to run at only one speed, so the carburetor was fixed. To start it you closed the choke and retarded the spark with a lever connected to the flywheel magneto. Then you turned a hand crank a lot, and then some more! When it finally started, you eased off the choke and it would speed up just a bit. Then you advanced the spark and it wound up to its full 1000 rpm. I must have been at least 30 years old when I used it in the mid 1950's and it still ran without a skip (once you started it).
I remember arguments between the man who tied the bales and the hay haulers. If the operator tightened down on the spring loaded shafts holding the top and botton of the bale chute together, it took more pressure to push the hay along the chute and therefore it would pack much tighter. It was possible with very green hay to get a bale that weighed well over 100#. That doesn't sound like much until you realize that you have to first toss it up onto the top tier of the hay wagon, and then toss it another eight feet or so into the hay loft.
   / Old Square Bailer? #13
Found this in the woods in one of my timber sale areas. I'm guessing its an old square bailer. IT still has old bailing wire twited and ready to go on the side of it. This looks cool and wish i could get it out of there. Its really heavy built out of cast parts. Some pics to enjoy.
I just came across one of these, and the owner did not have much info on the history. He uses it for demonstrations in Townsend TN
   / Old Square Bailer? #14
Here is a hay press in operation...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
FORREST RIVER CHEROKEE CAMPER (A50854)
FORREST RIVER...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
