Old Square Bailer?
/ Old Square Bailer? #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
Found this in the woods in one of my timber sale areas. I'm guessing its an old square bailer. IT still has old bailing wire twited and ready to go on the side of it. This looks cool and wish i could get it out of there. Its really heavy built out of cast parts. Some pics to enjoy.
The last pic is right before my battery on my cell died. The other side had a shadow on it and you could not read it, but was better defined than this side. It reads "Turner MFG Co Statesville NC"
/ Old Square Bailer? #3
That brings back memories of growing up on a south Georgia peanut farm in the late 1940's and 1950's. In those days peanut vines, with the nuts still attached, were plowed up, stacked on poles to dry, and then two or three weeks later hauled to a stationary peanut picker (combine) in the middle of the field, typically driven by a flat belt from a tractor. The picker separated the nuts from the vines, and cut the vines into sticks six inches or so long. The cut vines were dumped out the rear of the picker in a big pile.
Then one of these square bailers would be pulled up to the pile. Workers with pitchforks would toss the peanut vines into the open top of the bailer where a two foot square ram would compress the vines into a rectangular bale of peanut hay.
Your find has an "automatic" feeder that pushed the loose vines down into the bailer and then pulled back out before the ram pushed those vines into the bail chute. Ours had no such convenience. Foolhardy souls (like me) would push the vines down by hand quickly between strokes of the ram. Stories abounded of one armed men who failed to withdraw their hand before the ram passed by, but I never met one.
/ Old Square Bailer? #4
Agreed, it is a cool piece of history but if you got it out of there what would you do with it?? Just curious is all.
Man id lov to have the thing. It prolly weighs 1000lbs. But it rests on a Federal Military instalation that will go unnamed, and is thus unable to be removed. It Has im sure been there since the Government bought that land back in the 30's or so, probably out back of some old farm homestead.
as much as yall like pics and old stuff i cant beleive i only have 183 views and a handfull of replies, i really dont care but seems strange that we can go on for a week or better about a brush grubber that everyone knows about but something like this that is history only on guy told his story.
/ Old Square Bailer? #8
I would be willing to bet if you asked the base commander if you could have it he would likely be more than happy to get it off the grounds and might even be willing to provide help moving it.
/ Old Square Bailer? #9
Thats a neat old Hay press. I got one off an old clean up job one time. I cant remeber the name of it but it was in similar shape. An old man from Memphis TN saw it at my shop and gave me 800 for it and restored it. I bet the Bas comander would get rid of it if its about to be logged.
Heres a link to one on TRACTOR SHED that look real similar and sold for $500.
Used Farm Tractors for Sale - Hay Press
It would make a nice project.
Rich
It looks similar, except this model looks to attach to a drawbar via a fixed tounge and has 2 wheels instead of 4. It has more modern rims that had airfilled rubber tires on them that are rotted or burned off.
/ Old Square Bailer? #12
The one I used was made by Lilliston Corporation in Albany, Georgia. Lilliston made some of the first peanut pickers (stationary combines) and related equipment used in the south. Long Manufacturing Company also made them.
Our Lilliston Hay baler was similar to the one Rich referenced. It had a one-cylinder water cooled International Harvester motor with an internal gear reduction that ran about 1000 rpm at best. The motor had an enormous exposed flywheel. It was designed to run at only one speed, so the carburetor was fixed. To start it you closed the choke and retarded the spark with a lever connected to the flywheel magneto. Then you turned a hand crank a lot, and then some more! When it finally started, you eased off the choke and it would speed up just a bit. Then you advanced the spark and it wound up to its full 1000 rpm. I must have been at least 30 years old when I used it in the mid 1950's and it still ran without a skip (once you started it).
I remember arguments between the man who tied the bales and the hay haulers. If the operator tightened down on the spring loaded shafts holding the top and botton of the bale chute together, it took more pressure to push the hay along the chute and therefore it would pack much tighter. It was possible with very green hay to get a bale that weighed well over 100#. That doesn't sound like much until you realize that you have to first toss it up onto the top tier of the hay wagon, and then toss it another eight feet or so into the hay loft.
/ Old Square Bailer? #13
I just came across one of these, and the owner did not have much info on the history. He uses it for demonstrations in Townsend TN
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2025 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2025 B and B...
APPROX (24) 2" X 3" X 38" TUBING (A64280)
APPROX (24) 2" X...
2013 Chevrolet Traverse SUV (A61574)
2013 Chevrolet...
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
2012 Ford Expedition SUV (A61574)
2012 Ford...
