Old Sears Suburban SS12
/ Old Sears Suburban SS12 #21
Check to see if the flywheel key is intact
Yep, flywheel key is intact. I've had the flywheel off 3 or 4 times. I've had the magneto off and found a broken wire. That is why I originally wasn't getting spark.
Still continuing to mess with this when I have time. I've done a clean and install new gaskets and such in the carb. Still no start though. In playing around with this, you can feel suction on the carb as it is trying to suck air in. You can also feel air coming out of the exhaust as it turns over. Since I've been messing with this, now whenever I turn the fuel on and turn the engine over fuel comes out of a hole in the fuel pump. I've order a rebuild kit for the fuel pump. It should be here sometime this week.
/ Old Sears Suburban SS12 #24
i have a 1970 sears suburban and i dont know what to set the points at hope some one can help me at this thank you
/ Old Sears Suburban SS12 #26
mine has a switch on the shifter. it will only start with the clutch pushed in and the shifter in neutral & in the back center position...
/ Old Sears Suburban SS12 #27
have a 12hp suburban tractor, but cannot find were the shorting wire goes and connects to. anyone with good pictures or good diagram would be appreciated runs fine just cant shut off thru key beacuse wirefrom ignition not connected to motor somewhere .
/ Old Sears Suburban SS12 #28
Do you happen to no what year your Suburban tractor is. also, what kind of engine is in it... does it have a PTO.
Mine is about a '72 or '73. It has the 12 HP Tecumseh. I haven't messed with it in a while, but with starting fluid I will get occasional "fires" but sounds like the timing is off. I haven't pulled the flywheel off yet to get a new woodruff key.
/ Old Sears Suburban SS12 #30
It could be a blown head gasket too
Well guys, Saturday was a great day in the life of this project. It had gotten shoved to the side and I hadn't spent any time on it since this thread. I was moving out of the garage yesterday to a recently acquired shed. My son and a friend of his were there and they were helping. They wanted to hear what it was doing. So we started messing around with it. Low and behold, we were all thinking timing again - sound familiar? As I started to pull the flywheel off, the woodruff key fell out before the flywheel was even loose. So we proceed to pull it off and put it back together. I walked away to meet with someone that was there to pick up a goat. They tried starting it again and spraying it with starting fluid. The **** thing actually tried to start and actually did run for a few seconds. They went to the gas station and bought some gas and we put it in. It actually started and ran. We put the drive belt on it and it moved under its own power for the first time since 2002!!! Now, we couldn't let it run long as fuel was pouring out of the bottom of the carb. I jumped on ebay and actually happened to find a new carb for it. It is ordered and we will see when it show up. I also ordered a new fuel shut off valve for it....trying to keep it looking original. I will go to town and get fuel line, a battery, and a new drive and generator belt for it so we can actually get it running decent. I will also change the oil in it. Once I know it is running good, I will start the restoration process of it. Keagan's buddy actually went to trade school for autobody. I will have him lay the paint down on it probably with an automotive quality paint with clear coat. I don't plan on this being a worker any longer, but able to if wanted to be, but I want to be able to take it to the fair and display it and such.
Looks like Scotty was on the right track 8 years ago :)
/ Old Sears Suburban SS12 #32
Thanks for bringing us up to date on the project, your father would be pleased.
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2002 48ft. 38 Ton T/A Flatbed Trailer (A61573)
2002 48ft. 38 Ton...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
