Old Pickup bed as trailer
   / Old Pickup bed as trailer #11
Why not weld a hydraulic cylinder and run off remotes? I know you got it in ya Ron!
Hey Jesse, my thinking was use the hydraulics I already have. Tho I admit I don't know the cost of a cylinder to do the job. I also don't know where remotes are on kioti. I imagine they might be near all the backhoe hookups . But doing that implies a lot more work than just welding some tabs to bolt a cylinder to. The bed would need hinges and a frame to raise up from and rest on. Just conjecture off the top of my head again. I'm not much of a fabricator. I'd be doing well just to get the pickup bed and some suspension attached to the axle and some sort of tongue in place. Once I have the stuff in one place on the ground maybe I can figure out what to do with it. Keep yer powder dry.
   / Old Pickup bed as trailer #14
If I were to make that sort of trailer, I wouldn't mess with the suspension, just make it solid to the axle. It would bounce but if you are lookin for offroad use on your property it wouldn't be an issue, even on the road it wouldn't be bad as long as u didn't go highway speeds, as for the hitch you may also consider a pintle hitch rather than a regular ball hitch. The dump trailers we have at work run off of a battery, not the hydraulics of the tractor that way they can be used on a truck or whatever you want to pull them with that may not have hydraulics. That's my .02.:D
Thanks `dawg, the only reason I'm thinking of suspension is to gain ground clearance for dumping. I will checkout pintle hitches too.
I checked out pintle and Treg hitches. The pintle looks much more robust, the five ton version is over kill. But it's much cheaper then the treg hitch prices I saw. However, I think I was on an Aussie site. The Treg is a pretty good design for allowing vertical raising of the tongue. I pretty sure it would be strong enough. Either one will make it easier raise the tongue. The big unknown is how much of a pain it will be to push the trailer and guide it. I can always un hook and turn around to dump if I have to.
Suppose I mounted the tractor's hitch thru a whole in the b h bucket. Are the lateral forces that could come into play at low off road speeds that would preclude using the backhoe to tow with. I'd like to thank everyone for the generous help. I'm beginning to think with this quality of help we can get it done.
   / Old Pickup bed as trailer #17
Hi Ron, just thinking about your hitch some more. For a cheap hitch you could use the universal joint from a small truck, it would do all the treg would do but for a lot less money if you can get one used from a wrecker(breaker I think is the us term?) there would be a little fab to set it up but nothing to major. Good luck.
Ozy thanks, Thats a good idea. Should be plenty of those around.
   / Old Pickup bed as trailer #19
You wouldn't need suspension to get height out of your box, just block it up off your axle with a steel frame to the desired height. As for the hitch I wouldn't put any holes in your bucket, I would weld a piece of steel across the top of the bucket to strengthen it up then weld or bolt the hitch to the top center of the bucket, bolt it somehow if you want to be able to take it off for general bucket use. Another option would be to fab up a mount for your hitch which would quick couple onto the loader in place of the bucket but then you would probably want to change it out to use the bucket to level your dirt and it would be more messin around welding. At work we have pintles on backhoe buckets and move trailers around that way all the time, they push backwards rather easily as you are moving slowly enough, the only problem you may have is if u make to trailer too short it may like to jackknife but at the speeds u will be moving I wouldn't worry about it.
   / Old Pickup bed as trailer #20
I've thought about this a lot and concluded that I would want to have electric brakes on the trailer with a switch or brake controller on the tractor to lock them up in the rough terrain of west virginia.
I would put a receiver on the bucket and one on the rear blade to allow flexibility in towing options.
I would spend the money to make it dump hydraulically and I would put big tires on it to keep it easy to tow. A regular trailer tire and wheel set will sink like a rock and at any rate have a lot of rolling resistance, limiting payload severely.
2020 JOHN DEERE 444L WHEEL LOADER (A52709)
2020 JOHN DEERE...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2006 ford service truck (A56858)
2006 ford service...
Adams 6T (A56435)
Adams 6T (A56435)
