Old Pickup bed as trailer
   / Old Pickup bed as trailer #1
ron45
N.M.
Kioti LK3054XS
Hello, is this a good idea for a DIY dirt hauling trailer to use w/kioti? Some one is giving me an old truck axle. Don't know the make yet. I want to be able to use the loader bucket to tow, and raise the tongue to empty the trailer. I figure the truck sized tires and some suspension should get the bed up high enough to dump it by raising the tongue. Is there a hitch configuration what would make raising via the ball easier. That seems to be the iffy spot in my idea.
It would be easy to burn a hole for a 2" hitch. But I'm unsure if you could dump it by just raising it with the hitch ball and bucket. It's a fairly nebulous idea right now. I do own a welder, but I'm not a very good welder. Pickup beds should be fairly easy to find. But I have no idea what people pay for them. Anyone done this or something simpler. I don't want to get into a separate hydraulic system for dumping the thing. I have a mile of road that needs material in places. I am thinking that a trailer save so much back and forth w/kioti.
   / Old Pickup bed as trailer #2
This is just my opinion but were you planning on pushing the trailer you make backwards with the bucket on the Front end loader.. I am thinking that is going to suck . Or where you thinking of towing it from the drawbar then unhitching it and dumping it with the Loader bucket. I am a little unclear of your plan.
James K0UA
   / Old Pickup bed as trailer #3
I have a trailer made from an old 3/4 ton Ford. I cut the frame and formed a tongue without modifying the box/frame. It will not dump with my loader without a lot of trouble. I have to get it centred perfectly and then lift until the trailer is standing on it's bumper to get gravel to come out and then move it a little and do it again. It just isn't worth the effort. Making the trailer with a shorter rear overhang is necessary and then a small loader might not lift it. I'm planning to add sides to my tilt deck car hauler and unload with the loader.
James K0UA
At this point never having tried it, that's how I plan to do it. Drabar, unhitch, turn around, raise, seems kind of involved. I don't have trouble backing up a 2 wheel trailer backwards. Seems it might not be too much hard going front wards. But again this is uniformed conjecture. I appreciate your input James
I planed to raise the bed high enough above the axle to get a good tilt. But I sure do appreciate the heads up. I could also place the bed more in the direction of the tongue to help with that.
   / Old Pickup bed as trailer #6
Well maybe you have flat ground and can keep control of the trailer, by pushing it with the FEL. I could never do that here. Just too many hills and rough ground
James K0UA
   / Old Pickup bed as trailer #7
Re; Hitch configuration.
Have you heard of a "treg" hitch? It's used here in Oz for off road towing. It looks like a universal joint and would do what you need for lifting the trailer. I need to make some kind of dump trailer soon myself.
   / Old Pickup bed as trailer #8
I didn't have a pickup bed trailer, but just an ordinary 5' x 10' trailer and a 7' x 16' trailer, and raising the tongue high enough with my FEL to try to dump the contents of a trailer just never did work well enough for me to try it more than a couple of times.
More unproven conjecture here, I'm thinking that if I lift the bed high enough off the axle, and move the center of the bed towards the tongue I can get enough room to dump it properly. The metal bed should help there too. But it I have to use a shovel some to get it out of there it still beats running back and forth as far as fuel usage and wear and tear on kioti.
That's pretty good news Ozy. I was thinking of something with a heavy chain if the ball didn't afford enough range of motion but I will look into your suggestion. The chain wouldn't be much good for the steering part. Thanks for the suggestion.
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
Online Buyers Premium (A55272)
Online Buyers...
