Old oil tank
/ Old oil tank #1
JIMCT
CT (Central & NW)
JD4300, JD240, JD335
We have an old above ground oil tank in an shed that still has some oil in it. It has a hand crank pump and a hose and was used to fuel tractors maybe 8 years ago. Can I put this old oil in my house furnace tank? Would moisture or water in it harm the burner?
/ Old oil tank #2
Jim,
Throw it away.
I don't know if you've been reading any of the posts under Oil, Fuel, and Lubricants. But simply put, that oil is probably fouled with moisture and bacteria. I would dump it out into a container and take to a waste oil processing facility. Or use it to coat your shovels and other hand tools.
Terry
/ Old oil tank #3
I agree with Terry. Get rid of the oil. I did some environmental consulting work for a church that tried to use fuel oil that had sat in a tank for about 5 years. It clogged up their filter and burner. Expensive cleaning job. We pumped out the oil and recycled it. Expensive for them. All oil contains some water. The water forms a layer at the tank bottom. Microbes live in the water and begin to break down (eat) the oil.
2019 PETERBILT 567 (A67714)
2019 PETERBILT 567...
SKIDDED STEEL ROLLER (A68842)
SKIDDED STEEL...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
2018 JOHN DEERE 331G SKID STEER (A65056)
2018 JOHN DEERE...
2015 PETERBILT 320  T/A GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
PORTA POTTY (A67714)
