Old engine not running, Craftsman brush trimmer
   / Old engine not running, Craftsman brush trimmer #21
A common fault I have found with this type of engine, is that when they get hot, they cut out and stop and wont start until the cool down. Many time I have found the valve gap too tight. I think the valves get hot, expand, and so do not fully close. As far as the gap, if you carn`t get a manual, I would recommend having a bit too big a gap as opposed to one too tight. How much is plenty, well firstly these are not high tech racing engines, so as long as you leave plenty, say about 15thou. it should be OK. You might find there is no adjustment to the cam followers. The answer is to take the head off, take out the valve and grind a bit off the vale stem. Check the gap whilst putting pressure on the valve head until you get it too your liking then refitting the spring.
   / Old engine not running, Craftsman brush trimmer #22
TVS90-43022A is the Tecumseh model number for your engine
I checked the valves, .010 intake, .012 exhaust. I ran it some now that I've got heavy duty trimmer line, it starts running poorer as the engine warms up. As it approaches operating temperature, it starts smoking and starts missing on a cycle.
Every 10 or 15 seconds the engine hesitates for what seems like a single cycle, puffs out thicker smoke, and continues to run normally.
   / Old engine not running, Craftsman brush trimmer #24
A job to say what is going wrong but at a guess it sounds it might be the wrong jet.
   / Old engine not running, Craftsman brush trimmer #25
:shocked:I run from them there techumeshes:D
15ft Aluma Craft John Boat with Trailer (A57453)
15ft Aluma Craft...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2023 Texas Pride Trailers Trailer, VIN # 7HCM2UGT9PB039378 (A57453)
2023 Texas Pride...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
