Old "Bush Hog"
/ Old "Bush Hog" #1
crocket104
I have an old pull behind Bush Hog (and I mean old). The wheel adjustment for heighth is done by screwing a ratchet handle on a threaded wheel to turn the 2 rear wheels up and down. Each side of the front of the deck has a glide that reminds you of a sleigh rail. Can anybody tell me where I can get these runners or any other part for the mower. It is old and I do not have a model number. Thanks for the help.
/ Old "Bush Hog" #2
Any reason you can't gas axe and buzz them out of the scrap pile or flat stock?
Soundguy
/ Old "Bush Hog" #3
I think Soundguy has the right idea. If the skids are worn to a point of needing replacing, a piece of flatbar will work fine. I am not sure if I would remove the worn section, as it will make for a stronger skid if you can leave most of it and add to it. It also gives you something to weld to, which can be a help at times. I have a 7' bush hog that also uses the ratchet to raise and lower the wheels.
David from jax
Blue Diamond 103709 (A53317)
Blue Diamond...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
Caterpillar TL1055D (A62177)
Caterpillar...
FLARE STAND (A60736)
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
