Old "Bush Hog"
/ Old "Bush Hog" #1
crocket104
I have an old pull behind Bush Hog (and I mean old). The wheel adjustment for heighth is done by screwing a ratchet handle on a threaded wheel to turn the 2 rear wheels up and down. Each side of the front of the deck has a glide that reminds you of a sleigh rail. Can anybody tell me where I can get these runners or any other part for the mower. It is old and I do not have a model number. Thanks for the help.
/ Old "Bush Hog" #2
Any reason you can't gas axe and buzz them out of the scrap pile or flat stock?
Soundguy
/ Old "Bush Hog" #3
I think Soundguy has the right idea. If the skids are worn to a point of needing replacing, a piece of flatbar will work fine. I am not sure if I would remove the worn section, as it will make for a stronger skid if you can leave most of it and add to it. It also gives you something to weld to, which can be a help at times. I have a 7' bush hog that also uses the ratchet to raise and lower the wheels.
David from jax
TANK MANIFOLD (A58214)
1408 (A57192)
1408 (A57192)
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61567)
2025 JMR 72in...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
