Old "Bush Hog"
/ Old "Bush Hog" #1
crocket104
I have an old pull behind Bush Hog (and I mean old). The wheel adjustment for heighth is done by screwing a ratchet handle on a threaded wheel to turn the 2 rear wheels up and down. Each side of the front of the deck has a glide that reminds you of a sleigh rail. Can anybody tell me where I can get these runners or any other part for the mower. It is old and I do not have a model number. Thanks for the help.
/ Old "Bush Hog" #2
Any reason you can't gas axe and buzz them out of the scrap pile or flat stock?
Soundguy
/ Old "Bush Hog" #3
I think Soundguy has the right idea. If the skids are worn to a point of needing replacing, a piece of flatbar will work fine. I am not sure if I would remove the worn section, as it will make for a stronger skid if you can leave most of it and add to it. It also gives you something to weld to, which can be a help at times. I have a 7' bush hog that also uses the ratchet to raise and lower the wheels.
David from jax
VWS Toolbox/Fuel Cell (A61166)
VWS Toolbox/Fuel...
2007 Hyster S30FT 3,000lb. LP Forklift (A60352)
2007 Hyster S30FT...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
